Construction of a Buck Rogers Hangar
cylongirl
Galactica lives in Germany
Jan 3, 2015
1,198
3,396
95
North East Germany, Europa
Ich möchte gerne diesen Hangar bauen.
Leider ist dieses bisher das einzige Bild von dem ich mich leiten lasse, ich hatte es in meinem "Projekteordner".
Sollte also jemand mit Bildern helfen können würde ich mich freuen.
I would like to build the hangar.
Unfortunately, this is so far my guiding the only picture of the, I had it in my "Projects folder".
So if anyone can help with pictures I would be happy.
cylongirl
Jan 3, 2015
1,198
3,396
95
Das erste Tor/ The first goal
nun die Bemalung übertragen/ now transferred the painting
dann das ganze noch weitere zwei Mal/ hen the whole further twic
Mit kleinen Resten das Ganze dreidimensional gestalten, ähnlich dem Foto.
with small groups make the whole three-dimensional, similar to the photo.
jetzt eine Wellpappe um alles zu verstärken, Kleber war Holzkaltleim/ Weissleim
to strengthen a corrugated now everything, Kleber was cold wood glue / white glue
wieder vervielfältigen/ reproduce again
12,411
:surprise::surprise::surprise:
@cylongirl : THIS IS GONNA BE HUUUUUUUUUGE!!!!!!!
:bowdown::bowdown::bowdown:ClaphandsClaphandsClaphands:bowdown::bowdown::bowdown:
Holy frak, this is so awesome! But be aware, this "model" will take up MUCH space. There is a reason why I haven't continued my BSG hangar yet... I HAVE NO SPACE!!!
Please write down any dimensions of the parts. If you document everything carefully this could be the first step in making your very first cardboard model kit!!!
Make as many screenshots from the show as possible to extrapolate the look of the hangar. Take special care of items which were re-used from Galactica; you might find better views of these ones on the BSG DVDs. I guess the EDD hangar was modified in season 2 to be the Searcher hangar. Just take a look.
BTW, the template for a computer is here:
http://zealot.com/resources/searcher-bridge-console-1-18.511/
http://zealot.com/resources/searcher-bridge-console-1-6.510/
If you rescale the files to 1/32 it should look fine. (If you need any help with that drop me a mail!) :)
@Rhaven Blaack : Move along, move along, there is absolutely NOTHING for you to see here..! :D ;)
Reactions: cylongirl
Lee Clifton
Wisdom and Kindness, A Zealot Sage
Oct 7, 2015
268
173
40
71
Awesome! I've wanted to tackle this one too but haven't had the time.
9,966
I have this kit. I too have thought about making a diorama like this. So I guess, I will
be following this thread.
As @Revell-Fan I too would like to see dimensions.
Once I was able to get to itt, I too was going to very closely watch each episode that had the hanger and grab any screenshots that I can.
I wish you the best of luck. I will be following this thread closely!
I wish you the best of luck with it!!!
Gandolf50
1,327
1,576
96
New Mexico USA
Here you go...I do believe your model will have more to it than the actual TV set, which was flat black walls and a few standing props!
buckr600.jpg launch tube out of packing Styrofoam
Gordon__Rogers.JPG Flash Gordon and Buck...
Have Fun!
cylongirl
Jan 3, 2015
1,198
3,396
95
:bowdown::bowdown::bowdown:@Gandolf50 , danke.....mein strahlender Held. Perfekt!!
@RevellFan, Deine Räder messe ich Dir auch noch aus. Vieleicht wäre es gut Du machst noch einen Link für den Criton in 1/32
@ Gandolf50 thanks ..... my shining hero . Perfect!! :robot1:
@RevellFan , Your wheels I measure you also still pending. Maybe it would be good You're still a link for the Criton in 1/32.:robot1:
HGJ:animated::exterminate:
9,563
CylonGirl, you are the most industrious person on this forum. You never stop, and you really go till you're finished. You are a shining light! :)
Reactions: Revell-Fan
cylongirl
Jan 3, 2015
1,198
3,396
95
"Billig, nicht billig bauen" "Cheap build, not cheap"
Als Baumaterial hatte ich die Holzlamellen von IKEA noch rumliegen, die boten sich hervorragend an...
As a building material, I had the wooden slats of IKEA lying around that offered themselves excellently ...
und da mein Lieferant schon angekündigt hatte zur Jahreswende bekommt er neues Material wollte ich die Altbestände doch noch aufbrauchen.
and as my supplier had already announced at the turn he gets new material I wanted to use up the old stock still.
und auch ein Metallbaukasten aus der Jugend hatte noch Material
and a metal construction of the youth had material
kleine Plastrohre aus dem Baumarkt vervollständigen den Materialmix
small plastic tubes from the hardware store complete the material mix
Die Screenshots vom Film ausgedruckt und nun kann es langsam losgehen..
The printed screenshots from the movie and now you go slowly .
kleine Stellprobe/ small test
HGJ
9,966
