Faro Basso
9,564
They shall him, wonderful, counselor, the might modeler the ever lasting Modeler, the prince of peace, the ever lasting modeler, the prince of peace**** . Soon to bee the model of the month!!! :)
***borrowed from Handel's "Messiah" !!!
9,564
If you play a musical instrument let us know, I play the Violin, and push the buttons of my wife!! :)
Enterpriser10
Since the beginning. . .
Jun 12, 2011
183
247
Brazil
Wow, Zathros! Thank you for your kindly comment. It's honnor me, a lot!!!! Thank you, so much.
As the musical instrument, unfortunately I do not play anyone . . .
But, as Handel, he was inspired by the biblical passage in Isaiah 9:6, that was fulfilled in Matthew 7:28, 29 and John 1:18. That is, who am I to be compared to the Messiah ? . . .
Thanks for your precious encouragement, and it will be a great joy to be among the models of the month, if my humble Faro Basso deserve!
9,970
Just look that I found!!!!!
Can't you see????
A very small piece of green paper on which I cut from a previous step !!!!! And you know where it fits exactly?
Here!!!
And . . . the result? It's here!
View attachment 152980 View attachment 152981
View attachment 152982 View attachment 152983
Now, I conclude that this step is fully finished !!!
Rhaven, are you there???? Good surgery for you, my dear.
@Enterpriser10 Yes, I am here. I have to say that I am ENJOYING your work!!!
Having the ability to make minor repairs (with little to no expense) like this is a prime example of (one of the many reasons) why I prefer and so greatly enjoy paper model building over any other medium.
Reactions: Enterpriser10
9,564
Yeah, this is one piece that needs to be done from the "side not seen". :)
Enterpriser10
Jun 12, 2011
183
247
Brazil
Now, I'm looking at the part #8 . . . It's called by Uhu as "octopus", and it isn't without reason . . . It's very difficult to handle! :(
Enterpriser10
Jun 12, 2011
183
247
Brazil
Well, my friends, I think that the better way to start here is firming a starting−point on the limit with almost 0.5 mm from the extremities. But first, I need to fix the larger side of "octopus".
After, I'll try to glue the green part back, to join the fissure.
Then, I'll try to join the fissure in "octopus", gluing it at the green part back too.
9,564
Coming along nicely! You're going to have a little treasure there. Get a nice plastic box display, and when mounted, have two little holes drilled in the base, have them fill it with Argon Gas. Those holes have to be such that they are, when filled, can be plugged with glue, rubber, etc. It is not filled under pressure, it just displaces the air, and Argon is so neutral, it will prevent deterioration. The Argon is heavier than air, so you want to have the model firmly mounted, and put the fill and drain hole on the bottom, so when righted, any "air" will remain above the model. :)
Enterpriser10
Jun 12, 2011
183
247
Brazil
Great suggestion, Zathros!!!! It'll be amezing, and special. I'll look for Argon to home use, if we have it here, in Brazil . . . But, thanks for your scientific suggestion!
