Having a run at the Legal01 Re-envisioned Saturn V Mark III
9,558
Only problem I see is that it will all burn up when you fire it up!! Someone with some good "Shooping" skills could make a nice clip of that shooting flame. :)
Reactions: SonOfAGun2501
9,558
Sorry for taking so long to stick it, seeing how you were sticking with it, I didn't want to be seen as sticking it to you, so I stuck. I also again thank Legal01, someone whom I have respected for many many years, bring his treasures here. :)
SonOfAGun2501
Esteemed Member Extroadinaire
May 11, 2014
324
642
83
45
Ichikawadaimon, Japan
Okay, the thrust structure is under way. ( Please insert your own thrust joke here.) This no matter how you slice it, no pun intended, is a beast. Also, good thing to know if you are making this model in 8.5 x 11 in paper then your core is going to shrink down to 199mm as opposed to the listed 216mm for the core formers. If that turns out to be incorrect, I'll let you know but for now, I was just testing the size. Only other thing of note, part 1 and part 2 are maybe .5mm or so different in height so just shave them down and they will align perfectly. Then join them all together with part 3 and you have a very large start to something significantly larger. I know it would be tedious to do but maybe in future versions of this we could include some stringers. ;);)
SonOfAGun2501
May 11, 2014
324
642
83
45
Okay, ran into first problem today. On the thrust structure the red markings on part 6 have been flipped. So the piece is marked upside down. Sadly, I had already glued it but with a little excessive force I was able to remove it with no damage to the overall structure. thumbsup
20150729_152937.jpg Okay, these are 6 and 7. 6 is in the model should be rotated and on the left side.
20150729_154126.jpgAfter removing piece 6 and correctly inserting piece 7.
20150729_155014.jpg Old school tech. Fixed and ready to cut.
SonOfAGun2501
May 11, 2014
324
642
83
45
Well, it's been slow going but here are some updates. I have just started summer vacation so I should be able to get some more done on this.thumbsup So, without further ado. I have finished the bottom of the thrust structure. Can't wait to attach the engines but all good things in time. I have finished the central support and everything is nice and supported. Then finished the tabs for attaching the thrust structure to the rest of stage 1.
20150729_161803.jpg 20150730_162358.jpg 20150730_162409.jpg 20150730_165011.jpg 20150730_165502.jpg 20150730_165903.jpg 20150730_170428.jpg 20150730_174754.jpg
SonOfAGun2501
May 11, 2014
324
642
83
45
Here are the tabs all attached nice and pretty. For the last support I was supposed to cut a hole in the center...but, I didn't. Primarily because I forgot but it doesn't look like it will be a problem later so dodged the bullet on that one. Also started some of the detailing around the fairings.
20150731_161826.jpg 20150731_161833.jpg 20150731_163533.jpg 20150731_163852.jpg 20150731_164750.jpg 20150731_165022.jpg 20150731_171541.jpg 20150731_172405.jpg
SonOfAGun2501
May 11, 2014
324
642
83
45
This is the first time I have seen these and they are an awesome addition to the model. Here are the retro motors. I only had the pictures included in the parts 1 section so, this is what I came up with. A word of warning though, when you print these you will probably want to shrink them by 5 to 6% as they print up too large. Found that out a bit too late.
20150731_103229.jpg 20150731_103521.jpg 20150731_103613.jpg 20150731_103900.jpg 20150731_104013.jpg 20150731_104351.jpg 20150731_104400.jpg 20150731_104620.jpg 20150731_104625.jpg
