Groizer X - Space Pirate
Wow Rogerio!
You are doing fantastic, never would have known this is your first design.
Keep up the great work.
Your Friend,
Two can play...
Well, not really, at least for me. I'm just spamming you in order to raise my post count..! :mrgreen::mrgreen::mrgreen:
Anyway, keep it on! :thumb::thumb::thumb:
And why do you think I check your threads? sign1sign1sign1
Naaaah...:rolleyes: You know how I admire your work... BTW, have you checked your e-mails lately?:twisted:
All the best,
Rogério
I have. It looks great! What do you think? Shall we make some updates to the EAD thread? :cool::cool::cool:
I know this thread has been stopped for quite a long time, but I'm studying to get my PMP certification. This may take a little while, but I'll try to make time for the model. Sorry and thanks for the comprehension!
Don't worry, pal! We are all patient and understand that your resources are required elsewhere. Take your time and continue when you can. :thumb:
Keep your neck on...
RF
I think I can make time for the models; I'm just a bit behind schedule in my studies. Once I get back on track, I'll be able to make some time, and we can discuss a certain neck issue.
Thanks,
Rogério
Going back to the track...
Hello, everybody!
It seems I was wrong. Studying for the PMI certification took all of my time, but it sure payed off!
Well, after overwhelming the fear of failure (I should've known better than that already!), which is inherent to the process of test building my first designed model, I come back to you with my humble progresses.
Check the pics. I couldn't write a legend for each picture (I'm probable too dumb for that...wall1), so here it goes;
1 - glued the "sleeves";
2 and 3 - glued the "collar frames";
4 - the head support/base; and
5 - how the head base will look into place (not glued yet).
Oopsie!
Oops! :oops:
It looks like the model designer and the builder aren't getting along well. The first (me) forgot to tell the latter (me again!) what should be the order of assembly. After deglueing a few pieces, I found out that there are still some things to improve (aren't there always?), but it's just a tweak.
If you check the pic, you'll see that I unglued the "sleeves" because I've forgot the "armpits". And I've seen that the sleeves need improvement, as well as the black "frames" should be glued to the pieces before assembling them to the formers.
Please, don't mind if I start over, after all, it's my first model... :cry:
