Finaly I found the time to start my second project, actually my third but the first didn't turn out so well.
When I found the Imperial capital ships made by Milleniumfalshood I was obligated to myself to build the Imperial Star Destroyer after I finished the USS Wanderer.
I used to have the ISD from Airfix as plastic model but thrue time I lost track of where it went. Personaly I find the ISD a hugely iconic ship and it's appearance realy impresses me.
The model Milleniumfalshood created is simply stunning and is beautifull right out the box (printer). It's also very suitable for a lot of greebling which I plan to do so. I'm gonna try and make this a model that I can be proud of for a long time
It's gonna be about 65cm in lenght.
I did quite some custom work on the textures, detail and color in Paint Shop Pro and made it intirely to my personal taste.
Ok, the start.
I intend to make the main hullplates from different layers and started with the bottom layer of the top hull side.
The edges can be folded downward so you get nice textures on the underside of the edge that hangs over the side trench (wow, did that make sence? :mrgreen
The topside is made of five parts, 2 back, 2 middle and the front part.
So far the rightside back and middle part are ready and the fron is in the works.
This is going to be the bottom layer, another layer will come on top which will be thickend by approx. 3 millimeter. The difference of the second layer will be the edge of the hull that has a height difference.
The first pictures.
These are the two parts of the rightside joined together.
The second picture shows the folded edge on the underside, I used 1.5mm cardboard for thickness.
Ok, the start.
The first pictures.
