Master Uhu how in the world did you create those great realistic looking domes?? could you possibly explain more fully on which lines one should cut . I think that it is just the black wedges that should be removed but this does not explain how you created those fine lines that give it a glass paneled look. could you please advise. it is a very stunning effect and makes the whole model come to life. also i like the idea of using the material for making trees for model dioramas to add depth to the habitats within the domes.
Hi Samurai,
If I'm not mistaken...
You cut out the black wedges if you are making paper domes.
If you are making transparent plastic domes, you use the dome drawings as templates, to cut the wedges, then you scribe in the panel lines with a needle or some pointy tool...
(I kinda figured this part out, cause of building scratchbuilt models...)
As for gluing the plastic domes?
Well... I haven't fully looked at the download or instructions yet.
(edited; I was right, I just saw the templates for the clear plastic dome parts)
