....should I say "hope" instead of plan????
After almost 2 years of experimenting, I think I am getting close to an actual layout plan. I have started and quit at least 2 plans...I keep reading and seeing excellent projects on THE Gauge and keep changing my mind, so it's all y'alls fault, but here goes....:thumb:
I am planning a u-shaped shelf layout that will be 18'' wide, 8' on each side and 11' across the back of the U, built along the walls of a 11' x 11' room.
Right now, I want to concentrate on the middle section which will be a diesel maintenance facility and yard located between two or more towns with various industries on either side. The yard facility will be about 8' long. Operations will primarily be freight with interchange between other roads TBA later. The service facility will be light with fuel, sand, water and small engine house for repairs and RIP track. One or two engines with a switcher will be using the facility. There will be a small passenger depot along the passing siding at the top. I just don't have the expertise to design my own, so I found this small yard plan which seemed to be the ticket. For as you all know, I steal fair and square! sign1
Could the experts here take a look and advise if I am on the right track???
Questions I have would be:
1) would this fit (with scenery and buildings) on 18"?,
2) Where would you locate the RIP track?,
3) How long should the yard lead be?,
4) If the storage tracks are about 3' long, how many cars should make up a train leaving the yard?
5) John Armstrong says this plan will foul the main line while assembling local freight, I can't see how, if so how can I avoid that?
Sorry for the quality of the pic, I don't have a scanner and I just took a picture of the article. I am referring to the small yard at the top. The roundhouse will be replaced with a diesel facility building. If someone can convert this with a track planning program, I would love you forever! (Well, you know what I mean).sign1
I will have a gillion more questions, this should get me going. Thanks for your help, I will do what you all tell me!!! (Be careful here!tooth1)
ps- It will be N scale......
