That's amazing work DR Wayne. Thanks for explaining your painting process to us. It will come in handy for me in the future.
The closest steam engine (operating) that we have is a ex-CPR 2-8-0 operating in the Kettle valley steam train in Summerland. It has weathered almost exactly as Wayne has stated with the cab and tender staying glossy, and the boiler flatening slightly and the smokebox completely flat, probably due to heat.
Could you give use some infor on the tender herald? I notice it's straight but on many CNR engines it's 'tilted' and on others there is a round herald. One model I've seen simply has "Canadain National" in white across the tender. Are all these correct or do they show different eras of livery?
Thanks, Glen, both for the compliment and for the comment on the effects of weathering.
Back when the CNR was formed, locos had "Canadian National" spelled out in white on the tenders. In the late '20s, the "wafer" herald was adopted, based on one used by predecessor Grand Trunk Railway, which used a similar herald on its timetables since 1898, and also by another predecessor, Grand Trunk Pacific, since 1909. It was tilted at a 9 degree angle, and centred either on the tender side or centred on the coal bunker area - I can't see a pattern to which locos got which location, but different shops probably determined where
they put it.
In the mid-'50s, the "wafer" went from the 9 degree tilt to a position,
usually centred on the coal bunker, which was square: ie - not tilted. Some locos, like the 4193, also got a version of the wafer that had black shadow lining around the lettering. Earlier versions were red and yellow only, with no shadow lining.
In 1954, the circular "maple leaf" herald was introduced, probably to coincide with the introduction of the black, green, and gold paint scheme on the new lightweight passenger cars that the CNR was receiving at the time - these cars were also adorned with the same circular herald. Most, if not all, of the locos receiving this herald seemed to be ones primarily in passenger service.
Doc....Could you elaborate a little on the "plumbing" for the feedwater heater..?? Thanks...
Gus, rather than send you back to dig through the pictures in the original post, I'll re-post a couple:
This is the fireman's side of the loco:
Of the three pipes extending forward from beneath the cab, the upper one is the water delivery pipe from the tender. It takes water to the cold water pump, which in turn delivers it, via the large diameter pipe, to the heater "bundle" at the front of the loco. The small pipe on the upper right side of the water pump is the live steam line from the loco's turret (itself located atop the boiler, immediately in front of the cab). This pipe runs mostly under the boiler lagging, appearing just above the raised portion of the running board over the pumps. It supplies the steam which runs the water pump. (The other line coming out from under the lagging is the steam line to run the air pump.)
The other small pipe, exiting the upper left side of the water pump is the exhaust steam pipe - it too goes under the lagging, also to the heater bundle.
Moving towards the front of the loco, the cold water pipe passes through a clean-out, then enters the lower connection on the end of the heater bundle. (The inside of an Elesco feedwater heater is a series of tubes, filled with steam, that raise the temperature of the cold water by about 160 degrees F.) The heated water then exits the upper connection on the heater end and travels, via the lagged horizontal pipe above the cold water line, to the boiler check valve. (On this loco, the top-feed check valve can also be fed cold water by an injector-operated pipe on the engineer's side of the loco - this is a back-up should the fwh pump fail.)
The large, vertical, lagged pipes (one on each side of the smokebox) feed steam, exhausted by the locos cylinders, from the steam chest to the heater bundle.
Moving to the other side of the loco:
The other lagged steam line from the cylinders to the heater bundle can be seen. Immediately in front of it is a smaller pipe, exiting the bottom of the heater end cap, and heading in behind the air tank on the pilot deck. This is the condensate line (for the steam that has become water after doing its heating duties). It loops around under the boiler, passing through an oil separator, then returning the water to the tender. The other end of this pipe can be seen in the first photo - it appears from behind the water pump and is the lowest of the pipes as they disappear behind the cab steps.
Also visible here, on the engineer's side, is the cold water pipe that comes from beneath the cab, along the boiler to the top feed check valve. (Right behind the front sand box.)
Finally, a top view:
The two small lines which appear from under the boiler lagging, and run, on either side of the stack, to the heater bundle, are exhaust steam lines - one from the water pump and one from the air pump seen in the first photo. They also contribute steam to the heating process.
It was estimated that this type of feedwater heater, which used from 12% to 16% of the exhaust steam available from the cylinders, (leaving plenty available to maintain the draught) resulted in a fuel saving of nearly 15%. In addition, by reclaiming the condensate, an additional 1500 gallons of water (using a 10,000 gallon tender) is saved.
I hope this explanation is of some help.
Wayne
