That would work.
Thank-you Russ for all your help :mrgreen: :mrgreen:
That would work.
A couple of concerns come to mind: 1) How vertical and straight are your walls? I've been in houses where shelf brackets needed shimming to make the shelf level. 2) 1/4" plywood laid flat needs to be supported about every 12" or less to prevent sagging, or bending when leaned on. 1/2" plywood is good for about 16" to 18" between supports, and 3/4" plywood can go 24" or more. The other option with 1/4" plywood is to glue 2" thick foam to it to allow the 18"-24" separation between supports.
Based on the above, I would recommend an L-girder running bridging the tips of the shelf brackets. This will provide mounting and support for the 1/4" plywood. Similarly, run at least a 1x3 vertically along the back edge of the shelf bracket to support the back edge of the plywood.
hope this helps
Josh, I was just at Harbor Freight picking up a few small tools. I saw just the tool you would need to set up your grade for about $10.00. It is about 10 inches long and consists of a 180 degree protractor fastened to the center of a level. It is designed for contractors to figure the angle of stair cases, roof pitch, etc. It has a double scale on the protractor so it reads in both degrees and slope %. What you do is set the protractor to the % grade you want, in this case 3%, and lock it in place on the level with the thumb screw. Then you just put the level on the wall and balance the bubble in the center to get the level straight. Once the level is plumb on the wall, use a pencil to make a mark along the edge of the protractor and you will have a line going down the wall at a 3% grade. Lay a yard stick on the line and you can extend it, and just follow on until you are at your 12" below grade point for the staging yard.
hmmm... for the grade to staging, what about a rear track hidden behind big scenery (Hoffa Cement comes to mind), so the track can have a long run for the grade down. Or maybe hidden elevators?![]()
He is going to have a long grade down. I think he is looking a 36 feet to drop 12 inches. I think his plan is to have the grade against the wall with the staging yard in front of the tracks leading from the mainline to staging.
