All 11"? Any halfs in there?The grades on the layout are 2%, so your locos wouldn't be working too hard to pull trains around, the grade is 2.5% on the branch. The curves are all 11" radius, so you could run longer equipment like modern boxcars, 6-axle diesels, and passenger cars... although it's still a bit tight for full-size pass. cars.
Patience is something I have little of. (As I think some have noticed.Squitbait said:I think you're overestimating how difficult flex track is to work with. With the right tools (rail nips and a small file), and a little patience (measure twice, cut once), I think you'll find it's not as bad as you think it is. It's certainly worth the effort. The smooth-flowing curves that you make will let your equipment operate much more reliably, and look better than going from a fixed radius into a straight track... you notice on your oval how the train seems to slam into the curve, or snap out of it? With easements, the train flows into the curves.
This design was based on a 30" x 60" layout. I wanted to see if I could squeeze it down to 30" x 48". The 'pointed' section of the inner-most loop on the left side has a 1 3/4" section that dips down to 7 7/8" radius. All other curves are 9 3/4" minimum, just like the original layout.
I don't know if I could deal with getting the flex right without tossing it out a window.
I may be doomed to Scenic Ridge yet.
Well, partly because you can't lay flex track in RTS. You have to lay the whole thing out in snap track and then convert it to flex track. Hence, I have no flex track plan.Why? Because of flex track????
What's the matter Colonel Saunders? Chicken?![]()
Second- yes, flex track scares me.
Awww... c'mon! Put on your man-pants, step up and give it a try!![]()
Well, there's a couple of ways of doing it. If you're using XtrkCad, you can print out the track plan 1:1, and glue it to your benchwork, then lay your roadbed and track over it.
For fixed-radius curves, just take a ruler or yardstick, put a nail at the 0" end, and drill holes at the appropriate distances to draw your curves. Or you can draw out the curves on cardboard, and cut them out to use as templates.
As far as joints on curves, it's going to happen, but it's not a big deal. I typically solder 2 pieces of flex track together while they're straight on the bench, and then bend them around the curve. Yes, you have to trim both ends, but you have a solid joint in the middle of the curve that won't kink.
Egad.... I have to solder?![]()
That kills it right there. I have NO soldering skills. Espcially to work with something as fine as N gague track. I can glob stuff on for electrical work in the house and speaker wires in my bass cabinets but trying to solder something that small would be like a shark trying to have intercourse with a goldfish for me.
... see previous "Man Pants" comment.![]()
