Battlestar Galactica/Buck Rogers Hover Vehicle
12,428
Thank you very much! Chris is doing a formidable job cranking these out so fast. I'm simultaneously working on the instructions and a "little" add-on. Stay tuned! :)
9,985
Here are the parts for the "energy packs" and the intake system.
The "energy packs" are assembled. There are four for each side.
The "energy packs" are attached in place.
The intake system is assembled.
The intake system is attached in place.
This is a "step" that will be attached to the back end of the intake system.
The step is attached in place.
Both sides are complete.
Please stay tuned in to your local Colonial Broadcast Network as well as your local Earth Directorate broadcasting channels for more updates.
9,985
Here is a relatively short update.
These are the parts for the "propulsion units"
The "propulsion units" are assembled.
The "propulsion units" are attached in place.
9,985
Here are the parts for the "hover" mechanisms.
I attached the base plate in place.
The outside of the "skirt" is applied.
The "hover" discs are assembled.
The "hover" discs are attached in place.
The other components are attached in place.
9,985
Here is a quick video showing the Hover Vehicle
(*NOTE* I used two paper clips to hold up the vehicle, so that you can see the underside).
View attachment 20240410_210753.mp4
This vehicle is done. I will be starting the next version soon.
9,985
So, here is the next Hover Vehicle in the queue. This is the "EARTH DEFENSE DIRECTORATE" hover vehicle. This vehicle was featured in the "Buck Roger in the 25 Century" series season 1, episode 12 "ESCAPE FROM WEDDING BLISS".
Here is the template for the body. I have to commend @Revell-Fan for doing an ABSOLUTELY FANTASTIC JOB on both the colour and registry numbers for this version. :toast:
The body is assembled and the front grill is attached in place.
Both the trunk and main storage compartment are attached in place.
The internal formers are assembled.
The internal formers ar eput in place.
The operator's cabin frame, control console is attached in place.
The Operator's cabin interior is put in place.
The bottom plate is attached in place.
9,985
As I mentioned in an earlier post; @Revell-Fan and I were discussing ideas to improve the spoiler/trunk lid. This is what he designed (and what we finally agreed upon).
Here are the parts for the spoiler/trunk lid.
The spoiler/trunk lid is assembled.
I attached the "locking" piece.
Even though the locking piece is attached at 90 degrees to the inside of the lid, it is suppose to be attached on the "angled" side. This will allow it to slide into the truck and "lock" in place. (Yes, I fixed it after I attached it in place.)
I attached the spoiler/trunk lid in place, by gluing the gray piece to the inside of the trunk.
(as you can see I fixed the locking piece.)
The spoiler/trunk lid is closed.
