Building the Enterprise D (Rawen's New ish Model)
AdmiralGR
405
1,660
London
Bit or work on the secondary Hull.
Lower side and edge strips went on.
Few issues with the upper part tho.
  • The 2mm Card backbone turned out to be a bit "proud" so needed cutting back - a fiddly little task!
  • The Hull section that sits on top of the backbone was very tricky to stick down, tool ages and I had to do a little at a time and hold it down (in the background of the pics you'll see I was watching DS9 whilst waiting for the glue to dry!
About 2 hours of fiddly work!
mijob
Tie designer
3,187
5,393
95
Netherlands
Are you going to greeble some parts its seems that you can add a lot of exttas.
AdmiralGR
405
1,660
London
Love seeing this build thread!!! Making it come together!!!
Thank you
If I had it to build again ( which hopefully I will when the nebula versions released) I think I'd use 2mm foam board instead of 2mm Card. The D is top heavy at the best of times but the huge card disc in the saucer makes it a lump
Reactions: OldMiner
AdmiralGR
405
1,660
London
Stardrive and Saucer sections reconnected!
The back of the neck detail wss fiddly!
9,549
That has to be one to the cleanest Starship builds I've seen. It must be extremely sturdy. Very impressive!!! :)
Reactions: AdmiralGR
