Tie Bomber design and building thread
That looks REALLY GOOD!
Are the rings around the main body supposed to be raised or recessed?
Thanks RB.
Hhhmmm thats a nice suggestion I will look into that. I think I can raise them deppending on how wide the rings are. Also I need to keep an eye on the details on the duselage. So maybe I can make some cutted ring parts to fit between the details. It will make a huge difference. Thanks again for the suggestion.
Reactions: Awry_Chaos
I worked on the recessed rings. I cut the line on the fuselage between the rings, and it makes a huge difference. I will change the template. I attached an image I hope you can see the recessed lines.
Again thanks RB for the suggestion.
And this means more work for RF. :animated:
This is probably one of the best Star Wars models I've seen. It's definitely in the top echelon of models. :)
Thank You! Seeing this come together is a great thread. It's a model, model build thread! :)
