Colonial Viper Car
Starting on the engine block.
Here are the parts for the base of the engine mounts.
The base of the engine mounts is assembled.
Here are the parts for engine mounts.
The components for the engine mounts are assembled.
The lower half of the engine mount is assembled.
The two lower engines are attached in place.
The upper engine mount is attached in place.
The high engine is attached in place.
All of the side panel greebling is attached in place.
The rear greebling is attached in place. I "domed" the light above the license plate.
Please stay tunes to your local Colonial Broadcast network for further updates as they come in.
Moving on to the wheel assemblies.
Here are the parts of the wheel assembly components.
The wheel assembly components are assembled. As you can see, I "domed" the hubcaps.
The wheel assembly components are attached in place.
I have decided that I am going to build a diorama around this model. I have built a few accessories to go with it (yes, there will be more to come!).
Starting with a good mug. I made the pewter stein with the Eagle's head (@Revell-Fan helped me with the Eagles head).
Here is the Colonial Warrior Viper Pilot helmet
