Colonial Shuttle MK-I (Battlestar Galactica TOS)
9,932
After going through both the instructions and parts sheets, I realized that I had forgotten on the the components for the top (front) section.
This is a sensor array.
Here are the parts for the sensor array.
The sensor array is assembled.
The sensor array is attached in place.
Please stay tunes to your local Colonial Broadcast network for further updates as they come in.
9,932
I am sorry that this update has taken a bit longer than before. I had to raise the panels and add the greebles before I proceeded with adding additional regular parts.
Starting with the "top" side panels. I raised all of the panels and some of the piping that is directly attached to the panels.
Moving on to the "bottom side panels. I raised all of the panels and some of the side hatches that is directly attached to the panels
I added all of the greebling on both the "top" and "bottom" side sections.
Here is the other side.
I added all of the greebling on the underneath section.
micahrogers
3,773
4,639
Shannon GA
Thank you sir!!!
And they say that military intelligence is not. Even though, I am a GRUNT, I am still good at it! :cool:
I had to work with "Spooks" in my field as a sonar operator. It's amazing how much you can learn about a boat by the way it sounds. That's one reason modern USN subs use propulsors instead of screws.
9,932
Time for another update and some interesting photos for your viewing pleasure.
Now that the (majority of the) greebling is done, I can move on to adding more regular parts.
This is the rear bottom section that is right under and between the engine exhausts.
Here are the parts rear bottom section. Granted, there are only a few parts for this section. However, there is still quite a bit of greebling potential with these parts. With the duplicate parts, I am only going to show one assembled, and then both attached in place.
With this component, I raised the panels and recessed the circles and the vent.
This component is in place.
With this component, I raised the panels and the circles.
These components are in place.
This is a connector piece.
The connector pieces are attached in place.
With this component, I raised the panel that is on top.
The component is attached in place.
This is another connector piece.
With this component, I raised the panels.
These components are attached in place.
9,932
Now moving on to the front bottom section.
Here are the parts front bottom section
With this component, I raised all of the printed texture.
With these components, I raised all of the printed texture.20220516_084409.jpg
This shows the underside of the plate.
Since this area is curved, I have to attach the plate first.
Attaching the box on top of the plate.
