USS Ahwahnee (Cheyenne Class)
9,915
Start of the nacelles and some struts
When building the struts don't forget (like I did) to put part 110 inside the other parts. The struts should be 3 sheets thick. Too late for me to chnage it!
reprint and redo, or live with the mistake. I usually live with the mistake.
I have to say that this is one of the best things that I like about paper model building. If you make a mistake (which I have made this one countless times), it is an easy fix in the sense that, yes, you can reprint want you need and start over (which is what I would do and have done), and it does not cost an "arm and a leg" to do it. Granted reprinting and starting over is frustrating. However, it is worth the effort.
Reactions: AdmiralGR
AdmiralGR
405
1,660
London
Reprint not an option atm as I'm a school teacher and off work fro Xmas so not access to colour printer.
Sure it will be OK
Reactions: Rhaven Blaack
