Colonial Raptor (Desert Paint Scheme)
9,924
Thank you both very for the tips on how to make a plastic canopy for this beast. Once I am at a point where I need to make one, I will try my hand at both techniques and see which one gives me the best results and go from there. I will also post my results of both as well.
9,924
Here is an update on this current project! I have made the main engine thrusters.
Here are the parts sheet for one of them (Yes, I am making both:cool:).
Starting with the nose cone and working my way back.
The assembly of the first main engine thruster is finished.
As you see, I have added more detail by raising the textured parts, starting with the exhaust.
Both main engine thrusters are finished.
I now return you to your regularly scheduled programming. Please stay tuned to your local Colonial Broadcast Network for further updates as they come in.
9,924
Here is a minor update.
These are the parts for the center thruster support.
The parts for the center thruster support are assembled.
9,549
Just looking at the pictures again this IS the way to make this model. Greebling up those panel sections is really making it POP!! ;)
9,924
Thank you both. I am attempting to put in as much detail as possible. My fiance thinks that I have completely lost my mind. I had to remind her that: How can you lose something you do not have. :bulgeeye:.
Yes, it is quite a bit of work. However, If something is worth doing, it is worth doing right. The pay-off is indeed worth the effort. thumbsup
  • Haha
Reactions: ASC Mclaren
9,924
Now for the tail, fin and main engines assemblies.
Here are the parts sheet for the right section (even though, I am only showing just one side, I am building both sides simultaneously).
Starting with the vertical fin.
I raised the details on the back of the fins.
The fins are finished.
Here is the arrays that goes on top of the fins.
The arrays are assembled.
The arrays are attached to the fins.
9,924
Continuing on with the tail, fin and main engines assemblies.
Here are the components for the tail section.
The tail section is finished.
The tail section is attached.
I attached the fin.
The main engine is attached.
Both sides are now attached, as well as the engine support.
9,924
Here is the top DRADIS array.
Here is the base for the DRADIS. I raised the details on the sides.
Here is the part for the main array.
The array is assembled. I raised both the top and bottom details. With the top part, I cut out each part and laminated it on top.
The DRADIS is now attached.
9,924
Now for the nose mounted sensors.
Here are the parts for the starboard array.
The components are assembled.
The array box is mounted.
The probes are mounted.
Here is the part for the dome.
The dome is assembled.
The dome is mounted.
Here are the parts for the lower port array.
The parts are assembled. I raised the black parts on the dish.
The array is mounted.
Here are the parts for the port probe array.
The probe array is attached.
