UHU02'S DISCOVERY
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
switch and batteries came out of a hat bill. knew i kept that hat for something:)
main command pod light blocked and ready for a test
lite test!!
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
bell section glued together ( that was fun ) and attached ..
yes , some lite leaks, but i'm happy with it... i used a red colored file divider on the inside of the windows and if you look, you can just see someone in there..
9,549
Those models in the background deserve some attention in the way of posting some pics of them!
You're on the homestretch! :)
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
well, i was asked for pic's of models in the background.. i try to serve the masses :).
UHU02's Xwing
UHU02's Tie Interceptor
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
Space Pod by Ron Dreadnought by Brian Tan plastic model..C57D. 28 inch hull.. been hanging there for --umm ..about 2 years... yes, i will get to finish is... some time
Rocinante by Michael Grosburg
9,915
still learning as i go along. picked up a LOT of tips here on how to do things and the "hord" bug hits whenever i see something and think..." i might be able to use that !!"
This forum is the perfect place to learn new skills and techniques. SO by all means, please feel free to ask questions. Everyone here is always willing to help.
Reactions: lyter1958
9,549
12,361
FANTASTIC!!! :)
I noticed you have changed your avatar picture. I first thought the Rocinante was a gun :D ;) . Are you wearing a real hat or is it from paper?
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
i have before.. read a lot of tips on here.. read answers to others questions..
now the trick to water forming, current model i'm working on i used it to have it form right. worked like a charm, will be posting a build thread soon on that one
9,549
I started doing that with spoons, to make fenders for the Hot Rods, desperately trying to make "Rat Fink" Hot Rods out of paper. My Mom had so many spoons and ladles, I could always find something, then cut the shape I needed from the whole piece. Getting the mirrored part was the tough part. I learned much unknowingly, from all the mistakes. :)
