1:16 Space Shuttle flight deck
12,467
The screens look like real LCD screens! WOW! This is true craftmanship! :Bravo::Bravo::Bravo:
Reactions: otherwld
bigpetr
Designer/Master Modeler
Jan 27, 2016
924
1,468
Czech Republic
Bloody photos can never show it right:). Your photos looks great. For me I think it will be the kind of model you can not take your eyes off when see live.
Reactions: Tonino
Tonino
794
1,785
83
61
Republic of San Marino
www.facebook.com
I was away for a while, excuse me my friends. Summer time means to me less time for modeling and no time for posting.
I spent a lot of time outdoors and the wheater here was so sunny this year that we had no rainy day forcing to stay at home.
But I wasn't completely out of service... here is a little update on the shuttle project.
First of all, the knobs. I felt like the dashboard was a little too flat so I decided to add the two knobs to every screen.
Perhaps they are just a little too big, but this is the littlest diameter I was able to handle. Anyway I like the final appearance once they was mounted.
OK some of them look up and others look down... but perfection is not of this world... ;)
Then I placed the HUD boxes in place
Then I realized an element to close the lower part of the dashboard. All kept in place by the usual microtabs I always like very much.
Then I started to deal with dashboard upper wall, this part will help giving the correct shape to the front cabin wall.
The pieces at the bottom will form the lower side of this part, facing down in front of the dashboard panel.
Again I made large use of my microtabs
The three sections ready to be joined. The greebling on front panels is still to be done.
Tonino
794
1,785
83
61
www.facebook.com
Next I wanted to start adding the two middle walls but I realized that the tabs, once placed, will be unreachable so it won't be possible to keep them in place, pressed to the external walls. So I had an idea that can be useful in other similar situations.
I realized many little 90° tabs to keep the big tabs in the right position once they are closed inside.
These are the 90° tabs
and this is their application
Now the big tabs are forced to stay at 90° so I can glue them without need to keep them pressed.
Here we have a BIG problem!!!
Evidently I made a mistake taking measures and now the side wall elements are too short and don't reach the middle wall. I already corrected the files (so don't worry: the model you'll build won't have this bad fitting) but it's too late for my model, unfortunately I didn't notice this bug till now. I don't want to destroy the wall and build it back again. I'll study something later to cover that gap.
If you remember I had another bad fitting issue with middle walls in my first test build. At least those issues are now resolved:
Much better than the first try... isn't it?
And... finally, I placed the central consolle to the floor.
Now to the front walls and the windows...
See you soon!
12,467
@uhu02 : Please take a look at this! His skill and dedication is Japanese! :) ;)
@Tonino , show this to NASA and they will hire you as head of technical studies! :)
Cover the gap by printing out the correct portion of the area and glue it over the short piece. Remove the grey squares you glued to the surface first. Easy fix! :)
Reactions: xaero892 and Tonino
9,600
This is when obsessive compulsive compulsion is a good thing!!! :)
Reactions: Tonino
Tonino
794
1,785
83
61
www.facebook.com
:) well... RF, this is the best compliment I had received so far!
Nice idea. I was going to put in just a stripe with the right color to hide the gap but your solution is much more elegant. Adopted! ;)
Right Z! :) I think every modeller, more or less, has this disease in some form. The art is raising it to highest levels :wacky:!
Tonino
794
1,785
83
61
www.facebook.com
After my return to "post summer" configuration (sigh! :( ) I'm back to work (the real one...) and to modeling time too ;)
My first action is to follow @Revell-Fan advice to fix that bad gap in my left side wall...
I hate when I have to destroy something of what I've done... scratched away all velcro patches
...and this one it's done! :D
Now let's go on with the windows...
Windows frames looked somewhat flat... so I tried to add some more complexity to the volumes cutting a new series of frames
Now I like them much more.
The front wall is starting to have a definite shape...
And from "outside" too you can start to recognize the "face" of the baby...
10,015
I too have had to make repairs like that a few times on models. It is indeed a pain in the arse. With that being said, you have done a flawless job. The windows look AMAZING!
Reactions: Tonino
