YEP!
Do it!
... (puzzled looks, scratching heads: Well, what does he mean??? What the heck shall I do??? ) ...
OK, this is the deal:
Go to the SciFi section:
http://www.zealot.com/forums/science-fiction-fantasy.396/
Click "Post new thread", fill in the blanks and you are ready to go!
Since you are the thread starter you are the master of it. You decide when you post an update and you decide the pace of the project. So you may go ahead and post what you have already done and then let the updates happen as soon as they are ready.
As for rescaling the parts: I highly do not recommend using the snapshot tool because that will only lead to frustration. I'll explain: If you copy something from your screen the image is saved in your standard screen resolution (about 72 to 96 dpi or so, depending on your machine's specs). That means the copy will look extremely bad in the first place. Then you will need a graphic program to paste the screenshot and print it. However, if you use Gimp, for example, the picture is pasted in Gimp's standard resolution (72 dpi). If your screen res is 96 dpi, the image is printed too big if you don't resize the image before. In addition, the display value of a document is not the real value: If you display a document at 100 % in Acrobat and hold a 1:1 print of the page beside your monitor, you will see that the displayed image is a tad larger than the print. Just a note. If you have already discovered the percentage to print out UHU's parts to get a pleasing result, then proceed with that. I may do a tut on that to ... well, "display" the differences..!
I'm looking forward to seeing your build thread!
