De ja ... the feeling you're building a model you built before...
So, I had a busy weekend but did get around to finishing the port greebling and starboard main hulls.
In the process the phaser array got damaged... :headbange: but it needed work any way :)
So, experiments in lighting! I wanted the light to be dispersed for the warp nacelles, the LED on it's own would be too intense at one spot. So, with the LEDs, silcone sealant and a small 2ml plastic pipette ...IMGP0450.JPG
I was able to make this!
Sorry, I didn't want to solder to my bit of circuit board yet, so my finger's in the way. I packed the bulb of the pipette with silicone & the inserted the LED. I'm also using the bore of the pipette for other lighting area's (fibre optic principle :), thanks Zathros!)
The nice thing with silcone it can be cut to fit relatively easily and the bulb doubles up as a mould! :)
And here's the hull halves joined and an unlit warp light in the middle :)
Your deflector dish looks like someone backed into it. I'd revisit that seeing how the rest of the Hull is looking pretty damned good. IMHO. :)
Reactions: Cybergrinder
... paper Borg gets hit and unfolds into a flat piece of paper and sings, "Smoke on the Water"... :D
I always wondered if Bjorn Borg was a Borg? Maybe he was bjorn that bway? Bit's bhard bto bsay. Sounds almost like Pig Latin, a dying anguagelaybay. Obat adbay. ˙punoɹƃ ǝɥʇ uo ʇǝǝɟ ʎɯ ʇǝƃ ʇ,uɐɔ ʇsnɾ I ˙ǝɯ ɹoɟ uʍop ǝpᴉsdn ʎllɐǝɹ ǝɯɐs sƃuᴉɥʇ ʎlǝʇɐ˥
˙ʇooqǝɹ ɹǝʇʇǝq 'pɹɐoqʎǝʞ ʎɯ ɥʇᴉʍ ƃuoɹʍ s,ƃuᴉɥʇǝɯoS
