Gandolf,
How's everything going? Any new progress on the Vorchan? I've been designing the little purple blocks right behind the "head" and some of the surface features on the fuselage.Trying to figure out a way to make it easy for people to build and line up the blocks. I might have something in a couple of weeks depending on work.
Just wanted to check in and say "hi".
Take care.
Sky Seeker
:tank:
I have not been doing anything for some time, side tracked on other projects, as well as all the stuff Spring Time requires doing!
as far as the Vorchan it looks as if I am going to start from a clean slate and re-start, re-build section by section. Do to the amount of detail I want to include ..I have to at least double the size, which requires a total re-work ( re-compose) of the parts from the wings forward! I also need to create UV data for virtually all the parts as there is none except for the head and wings. Do to the way I will have to re-configure and build ( which should have been done in the first place) I have to select every part and separate and assign a different UV and color so that they can be textured and flattened. Something like this...
Things are not lost...I don't have to dump everything .. if you remember that cross that was in the views of the SGV files? well that was a flattened 1x1x1 meter cub that was placed next to all the parts to be flattened to maintain and control size via different programs...so most of the stuff is still useable.. just needs to be re-organized and broken down so that the thing can be enlarged and still fit on A4 / Letter size sheets, and instead of moving all those parts to different layers, which started to put a drain on resources when running several programs at the same time.. split them up to different files to control things and memory ( computers and my own)
