Colonial Viper from UHU02
McTschegsn
240
509
Dreieich, Germany
www.jet-connection.de
Hi friends... Just took my time and continued a bit on my Viper.
The lower engines are finished and glued to the model.
The pipings will be done shortly before finishing the model. I am afraid of mashing them up when I handle the model while glueing. For the same reason I will leave the throttle stick (which broke the umpteenth time) alone and put it back in the model when its finished... Easier to handle :D
Up for a bit eye-candy and the actual building state
Ther are still some erratic edges on the engines backsides which I will cover upo with the next former to be installed...
silveroxide
2,036
525
Fayetteville NC
Thanks for sharing. I recommend that sometime later, make another printout of the seatbelts. I like the build so far, especially in how you have kept the frame straight. I had a slight problem in the nose section, which wanted to droop down. Those wing strut attachment are very fragile. Protect them because they will bend very easily. Set the viper on a raised surface to keep the struts from touching the surface.
Reactions: McTschegsn
McTschegsn
240
509
Dreieich, Germany
At the moment the struts do well. Nevertheless I will follow your advice. I fell in love again with this model while continuing the build. I definitely like Uhus style (and the Viper of course) :D
Plus I want to finish this thingy as I have tons of stuff to do and I hate billions of parallel projects ;)
9,577
Holy Crap, you McTschegsn'd the Hell out of that!!! picture uploads got knocked out again, I am happy you got some in though. It's being worked on. Beautiful craftsmanship. ;)
