pepakura designer
Discussion in 'Tutorials' started by rkelterer, Nov 1, 2004.
  1. rkelterer
    rkelterer Member
    first I removed the texture, so moving and rotating the model with the mouse is much faster.
    then I defined the cut lines - these (brown) lines will be pre-cut by pepakure all others (blue)
    are folding lines, which will produce folding edges on the end. the actual selection is green.
  2. rkelterer
    rkelterer Member
    all of them
      File size:
      30.8 KB
      234
  3. rkelterer
    rkelterer Member
    all of them
  4. rkelterer
    rkelterer Member
    the second try - the result is much more reasonable :)
      File size:
      39.3 KB
      236
  5. rkelterer
    rkelterer Member
  6. rkelterer
    rkelterer Member
    the parts might be cut and rejoined - pepakura tracks which parts are involved - so it is relatively easy
    mark the edge and click cut it
      File size:
      19.1 KB
      222
  7. rkelterer
    rkelterer Member
  8. rkelterer
    rkelterer Member
    parts can be rotated around any point interactively - first mark the center of rotation and then pick another point and ...
      File size:
      36.9 KB
  9. rkelterer
    rkelterer Member
  10. rkelterer
    rkelterer Member
    rotate it
      File size:
      34.4 KB
      233
  11. rkelterer
    rkelterer Member
  12. rkelterer
    rkelterer Member
    move it
  13. rkelterer
    rkelterer Member
  14. rkelterer
    rkelterer Member
    mark an edge - papakure will find the other edge -
      File size:
      28.5 KB
  15. rkelterer
    rkelterer Member
  16. rkelterer
    rkelterer Member
    and join
      File size:
      27.2 KB
      223
  17. rkelterer
    rkelterer Member
  18. rkelterer
    rkelterer Member
    after several minutes you will have the new unfold result :grin:
      File size:
      39.3 KB
  19. rkelterer
    rkelterer Member
  20. rkelterer
    rkelterer Member
    now fine tuning with the flaps - again, pepakure knows about both edges of a connection -
      File size:
      34.8 KB
      220
