Flip an Unfolded Part in Pepakura?
Discussion in 'How Do I...' started by DJPinter, Feb 7, 2018.
  1. DJPinter
    DJPinter Trusted Confidant
    Is there a way to flip a part on the 2d pane in Pepakura? When Pep unfolds a round-cornered box the top and bottom get flipped so that the interior sides are facing "up" on the printed page.
  2. zathros
    zathros -----SENIOR---- Administrator Moderator
    Copy the Development to the Clipboard, use XNViewMP and import the Clipboard, you can do whatever you wish after that. You can't save it as a .PDO but as a jpg and do that for all sheets, size as necessary in XNViewMP.
    Link = https://www.xnview.com/en/
  3. Gandolf50
    Gandolf50 Researcher of obscure between war vehicles... Moderator
    Don't Know if this would help or not... but you could ( I have not tried it as yet ) but in both versions 3 and designer 4, under 2d in version 3 and under Other in designer 4. There is a mirror function (in version 3) and in Designer called Mirror inversion 2d and 3d. ( jeshh that was long winded...) anyway... I do know it mirrors the whole unfold, textures and all. It should be possible to take the one part you need inverted and delete everything else invert, save that part as pdo, and reload the pep file and merge the part with the original.. in the case of a box... just a mirror should do it, but would have to see the file. Hope that helps...;)
  4. daishi
    daishi Member
    Depending on the printer, the driver might support mirrored printing.
    So you can move any part that you need to mirrored, and for that page use mirrored print.
    Or you can have pepakura export as multi-image and use an image viewer/editor that can mirror the pages that need it.
  5. zathros
    That's a lot of work. I'd just convert the model into a .pdf, and go from there, you can extract pages, and mirror them in XNView.
  6. DJPinter
    Sigh...I thought there might have been a easier way to do it. I'll stick to printing to PDF then editing a pdf "page" in Photoshop or Pixelmator. Vertical Flip works well.
  7. zathros
    It's good that you asked this question. I think you will get better results editing in Photoshop. Pepakura can't make circles!!! ;)
  8. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    Yes, it can. It makes nice, edgy, jittering circles. :D ;)
  9. Gandolf50
    I guess I should have asked first.. but what do you mean by FLIPPED.. Inside out flipped or Upside down flipped? I guess I would need to see the PDO to answer properly!
  10. DJPinter
  11. DJPinter
    I solved my issue by redrawing the parts in Rhino. I either mirrored the object and rotated the copy over the original, then deleted the original or just put a plane on top of the part and trimmed the plane to the original part shape then deleted the original.
  12. zathros
    Dude, if I know you had Rhino, I would have told you to import the image as a "PictureFrame", then under "Transform" "Mirror it (Turn Ortho on) and make the part the same size as the "Picturerame", and the "Pictureframe" the same size as the original. This will allow you to print to file, and then use XNViewMP to make a final properly sized jpeg. You can do virtually anything when it comes to picture manipulation with Rhino. :)
  13. Gandolf50
    :loudspeaker: NOW HEAR THIS..another Rhino modeler willing to do stuff for FREE... Dj ... Like Zathros said!! Especially BOXES!;)
  14. DJPinter
    Hold up a minute there Tex. :surprise:
  15. zathros
  16. wulf111
    wulf111 Member
    in Pepakura go to the top menu and choose other, under that choose Mirror Inversion (Both 3D and 2D) . that should fix your problem.
  17. DJPinter
    Thanks, but that’s for the entire model, not just one part.
  18. DJPinter
    Actually, I do boxes. They all look like this:
    [​IMG]
    They eventually turn into this...
    [​IMG]
    Then this guy shows up spewing something about how he’s got such sites to show me.
    [​IMG]
    I just say, “Dude, I’ve been to Cleveland.” Then he looks all disappointed and walks off while pins fall off his head.
    BTW...
    [​IMG]
    (BTW, not mine)
    Revell-Fan, zathros and Rhaven Blaack like this.
  19. zathros
    Very nice!! :)
  20. Gandolf50
    actually what we were getting at was , take the ONE part flip and save file..load complete file ... merge saved part and tada..part flipped...
    but since you have Rhino..the point is mute..;)
    BTW nice boxes.. I haven't seen them in awhile..
