"toronto gosh!" said 3-P0 or "lets build an AT-AT"
Awesome! Very well done! :)
Yes, the model is the goto AT-AT papercraft. The only area which could be improved are the tubes on the bottom (by wrapping paper strips around to give the illusion of differently sized diameters?). But since you rarely look at that area (unless you are attempting to blow it up with a grenade) this is a fairly minor aspect. I love your foam idea, that should be added to the instructions! :)
Thanks for the praise - yes the tubes were a bit poor, although mine do function and slide within each other as for posing.
The foam idea was very off the cuff, but it seems to work, they were all over the place and I just didn't want them glued up.
...now where did I put that grenade?
