Shake that Ass! ~ Eminem
But...!
Ok, no butt jokes, please.
But, it is a butt..... Or, the bits of the butt.....![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![001.jpg 001.jpg](https://www.zealot.com/data/attachments/98/98643-a0c5e9b91496fa0c71fe4bd51efbcca6.jpg)
So, the bits of the butt are built....!
And the upper side pieces are made ready..
![012.jpg 012.jpg](https://www.zealot.com/data/attachments/98/98644-cce1bcd376e771b9cffcb2802c2ceaff.jpg)
The upper side pieces were attached and the earlier assembled legs were then attached. I want to make sure that the feet sit correctly on the rock, so as I said earlier, this part is crucial to get right, as the angles and attachment points of the internal armature, where it connects between the legs and upper body needs to be accurately aligned.
So, a quick test fit........
![028.jpg 028.jpg](https://www.zealot.com/data/attachments/98/98646-d210cbe7c8611a56d0995c092dd493a1.jpg)
![027.jpg 027.jpg](https://www.zealot.com/data/attachments/98/98647-90573d74057559b78e9fec13391a483e.jpg)
![034.jpg 034.jpg](https://www.zealot.com/data/attachments/98/98648-b4b0e69d3d51dad605fb0b8090d4b9e1.jpg)
The feet and claws all seem to be 'gripping' correctly on the rock. I'm pleased so far...
I still have to add more pieces to the hips to stabilize the structure before I align the leg armatures ready for attachment to the upper body armature....
A few twists and bends required here, obviously....![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![026.jpg 026.jpg](https://www.zealot.com/data/attachments/98/98645-44f82cdf391f4af3d7715d22754a8907.jpg)
I eventually motivated myself to finish the repairs of the upper body and attach the wing.
I extended the cut off wing armature, using a piece of stiff wire and binding it with thinner wire, then dropping a few drops of CA clue to hold it all together..
![016.jpg 016.jpg](https://www.zealot.com/data/attachments/98/98649-3b49b53d596262f0417509d933d91c35.jpg)
Once the replaced wing pieces were glued to the body, the extension piece of the wing armature was attached back onto the main armature in the body with thin wire and CA glue, as before.
![020.jpg 020.jpg](https://www.zealot.com/data/attachments/98/98650-36cd3bf4abdec9d2cfabf8411611a868.jpg)
I am not happy with my execution of attaching the body to the wings, I found it a hellish nightmare to achieve. I have a few small repairs still to do, but, the main construction is done. But, LOTS of colour touch-ups still to do though. Also, all the damaged spikes I will repair at the end of the main construction.
![022.jpg 022.jpg](https://www.zealot.com/data/attachments/98/98651-aa9f15473511c446b0318f36507a2182.jpg)
And at least I can now show you the LAST PIECES of this draconian jigsaw puzzle, cut and edge coloured, ready for assembly.........bounce7
![029.jpg 029.jpg](https://www.zealot.com/data/attachments/98/98652-896038cea935261d67fa966bee142d3b.jpg)
I think, if all goes well, my next instalment will be all about bondage.....
Bondage of the upper to lower assemblies.....:mrgreen:
But there might be a sting in the tale..... But there again, you need a tail to sting.......![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CU!
![Wave :wave: :wave:](http://images.yuku.com/image/gif/c5cc0cf5a25b4d648169e7ff9f089cb5.gif)
But...!
CU!
