Hiya Folks
I'm trying to figure out yard operations here that will work the best for the
amount of room I have on the layout
I made a couple yard versions up and I'm wandering which would be the more
effective.
When a train comes off the main line pulling the train into the siding which is
attached to a stub yard would the engine disconnect from the cars run back
around to the rear of the train cars and push the cars into the stub end Or
would the train pull in disconnecting the engine then a switcher come into play
breaking the train apart on the siding and sort the cars as there put into the
stub end yard?
Here's the 2 versions I did both work although the second version works better
if the engine is going to drop the train cars as one group then a switcher come
and starting from the back take a few cars at a time and run them down to the
stub yard. The first version can't do it that way as there's not enuff room for
it to back up with the cars.
This is Version 1
This is version 2
http://img243.imageshack.us/my.php?image=yardver23pv.jpg
effective.
stub end yard?
This is Version 1
This is version 2
