xtrkcad ?
Hi Roger:wave: . Inch marks? Do you mean along with the footage marks on the grid? Or track measurments?
For elevations, go to change, then elevations. After the box comes up, click where you want to change elevation, and enter the amount after pushing the define radio button.
Good Luck
Loren
Also, if you haven't done the free registration there is a size limit, 4x8, if I remember correctly.
Roger, as far as I know there are no inch marks. You use the ruler instead. On the button bar, it looks like a line pointed down. Click and drag to use the ruker.
Loren
I get an inch grid if I select the icon that looks like a checkerboard, or options grid, select the show check box. First, in options grid, set the sizes to what you want, it looks like it is in inches.
Jeff
