Upgrading an Athearn BB F45
DanRaitz
300
Maricopa, AZ, USA
I decided to do an upgrade of a Athearn F45. I've had this loco for over 20 years and it needs some tlc.
Here are a couple of shots before I start tearing into it.
My first step was to redo the chassis, which means rebuilding the recessed step in the fuel tank. I cut out the area with a Dremel tool and then rebuilt the step with styrene and body putty.
After I finished with the chassis it was time to reinstall the motor and a DCC decoder.
Now to complete work on the chassis. Here I finished the truck sideframes and attached them to the trucks. But before I could do that the trucks and wheels needed to be painted.
I then added the brake cylinders and brake lines to the sideframes. On the left front there is a speed recorder attached to the center axle.
I then painted the sideframes black installed them onto the trucks.
Here is a shot of the completed chassis.
p.s. Josh, the air tanks are from Details West #AT-204
Now that the chassis is complete it is time to start working on the body.
The first thing I did was to scrape the mold lines and strip the old paint off.
I then started to remove the molded-in detail that will be replaced, fans (both radiator and dynamic), the exhaust hatch, the inertial filter hatch and all the grills along the side.
To do this I first drilled a series of holes in the area that is to be removed, then cut that area out with a hobby knife and used files to square the openings up.
Here are a couple of shots showing the shell after all this surgery.
You're in Grand rapids,huh?Not so far away from me,about 75 miles or so?
Cool stuff,I wish I could do that.
Chris
I have started to rebuilt the loco. Starting with the inertial air filter area. To rebuild the grills I used a radiator grill from Cannon & Co. #1401. I cut and sanded it to length and then split it lengthwise.
I then installed these in the openings and installed the inertail filter hatch.
Next I attacked the front pilot. First I removed everything from the steps forward.
I then made a paper template of the rear pilot and transfered that to .020" styrene.
I then installed the pilot and cut out the slot for the coupler.
I then finished installing the details: plow, air hoses, coupler lift bar, etc.
I also rebuilt the radiator section. To do this I used Robert Zenk's F40PH article in the July 1983 Mainline Modeller as a guide.
Here is a view of the left side rad.
and the right side
