Maintenance robots 'Dewey', 'Huey'and 'Louie' designed by UHU02
thegreek270
53
24
Greece
Hi Rhaven Blaack,
beautiful work with the drone thumbsup. I love the raised components. It makes the model look more realistic.
I'll try to do the same when I'm finally get to build mine. I'm still cutting out the parts and there are still other unfinished projects.
Great that you provided very detailed pics about the arm assembly. They can be used as reference when building these guys :)
I think the arms are the most complicated parts on this model.
Well good luck with the other two drones.
I'll be watching closely. ;)
greetings from greece
thegreek270
Reactions: Rhaven Blaack
ADMINISTRATOR
3,996
183
Hi Rhaven Blaack,
thegreek270
Thank you very much. was a fun model to make. I am quite certain that the other two builds will go easier (now that I have the model mapped out in my brain).
You are right. The arm assembly is the must challenging part of the whole model.
I look forward to seeing how yours turns out! I wish you the very best of luck with it and I hope that you enjoy the build as much as I did.
Dagger
210
443
40
Extraordinary work. This, like several constructions that little by little I go snooping are invaluable to be learning to detail a model, which although in itself is already magnificent, can always be improved with something extra.
ADMINISTRATOR
3,996
183
Thank you very much!
Taking printed texture and layering it (either by raising, recessing, or a combination of both) is the most simple (and quite effective) way of adding detail to any model. I learned this technique with building the BRTC25 Thunder Fighters and adding detail. Please check out the "Detailed Thunder Fighter Project". There, you will find ideas on how to easily add detail.
