Hello friends.
On FIGURE 1 is model of tube (red part) with diameter TD (tube diameter). I want to make it from 160gsm paper with thicknes PT (paper thicknes cca 0.2mm for 160gsm paper??). If I want paper tube to have diameter TD do I need to adjust TD for unrolling to flat pattern?
If I want a cap (blue part) like on FIGURE 1, will be CD (cap diameter) same as TD or should it be smaller like hinted on FIGURE 1?
Same question for FIGURE 2. I have model of tube with diameter TD and I want paper model of that tube to have inner diameter TD. How to adjust TD for unrolling to flat pattern? And what should be diameter of hole in blue part?
Or am I overthinking it? Do you even consider paper thicknes when designing?
Thank you or your answers
