If your high rail vehicle is going to be a flat bed, you might be able to put the motor under the hood. You may need to raise the floor of the cab interior a bit to get clearance, but lpb's work as well without legs as they do with them!
I have never heard of them so until now, I have not. However since you mentioned it I checked them out, but it does not look like they have anything in the size I am looking for. Thanks for the suggestion though.Have you tried Backwoods Minuatures
If I have to go with the larger motor, then I will probably leave it as a box truck, but I was hoping to go with the smaller motor between the frame because it fits so nicely. However I am not opposed to disguising the motor as some type of cargo. I was really hoping to go for the effect of "how'd he do that?" by using such a small motor making it seem impossible to power it elsewhere. Putting the motor under the hood might not be a bad idea, it might get messy but it is very much a possibility....I would put the motor inside the bed of the truck rather than trying to hang it under the frame between the axles. If your high rail vehicle is going to be a flat bed, you might be able to put the motor under the hood.
Not in this case as they will need their feet to push on the gas....but lpb's work as well without legs as they do with them!
Front wheel drive is now out of the question as I have JB welded the gear to the rear axle and would prefer not to have to tear that apart. I suppose I could run a drive shaft from the motor in the cab area, then it would look pretty prototypical, although I do not know what kind of problems a shaft like that might create....then why not make it front wheel drive?
Hmm...I will have to think about this one. Umm...nope it still looks funny.:mrgreen: However that Caddie sure has class! Maybe that will be the next project.:twisted:And for the record, I don't think it looks funny... I think it looks like this:
The heat is one of the main concerns but I like your idea, right in front of the grill mounted above the bumper. Disguised as an air tank or maybe a winch, great idea!Probably a stupid idea, but if the main problem with a resistor to drop the voltage is heat, perhaps you could mount the resistor in front of the vehicles grill, like a pneumatic cylinder. Or represent an air tank?
Is it possible to find a proper resistor that will cut 12v down to 1.2v? Everything that I have read so far suggests that it is not possible. That is why I was hoping the Zener diode would help. I am not sure of how many amps the motor pulls as I cannot seem to find the car and battery that this originally operated in. I will have to see if I can find something to test this with. However, I might have found a similar sized motor that can handle up to 3v. I have yet to find the exact dimensions, but if it is close then that would help keep the down step a little less drastic.The resistor will not get hot if it has the correct power rating, or like you said, use multiple resistors. Will you be able to control the speed somehow? What is the current draw (amps) of the motor at 1.2 volts?
Yes I will need one, I was planning on using a Z scale decoder and either hiding it somewhere in, under, or on the truck by placing it on the bed and covering it with a "tarp". However, I am concerned about how the voltage reduction will effect the operation with the decoder. Obvioulsy the reduction would go between the decoder and the motor, but I do not know how things will behave....you need a decoder, no??
I was affraid someone would say something along these lines. So you think it will still have that effect when the regulation is placed between the decoder and the motor? Theoretically the decoder would still function the same and put out the same amount of voltage, but the motor would only receive a fraction of that voltage. I was guessing that because the motor runs on such little voltage now, that it would still be sensitive to the decreased voltage from the decoder. Is my reasoning correct? Does anyone know what the smallest amount of voltage is that a decoder puts out when starting to accelerate?I think a decoder will create an additional complication. Decoders are designed to take 12-14 volts in and then turn on the voltage as needed to run the locomotive at the speed that you want to run. Trying to get a decoder to operate a 1-3 volt motor with speed changes may be difficult. If you just "crack" a little voltage to the motor, it might work, but at that small a voltage your controller will be more like an on/off switch.
You most certainly may. However I was looking into circuits that were along those lines and they all seemed to be way too involved requiring many components that would not easily fit within the space allowed. Either that or I was looking at example schematics of how they could be used. Can you elaborate more on the use of this device? In theory will the only components I need is this LDO and two resistors? Or will it take two LDO's, one on each wire to the motor to allow for the change of direction? Also, does this regulator work by limiting the voltage up to 1.2v or does it build up the voltage until it has 1.2v and acts like a constant voltage device?Can I suggest a linear voltage regulator?
It will depend on how much current you need but I know there are many that drop 12V to 1.2. I do this all the time to power FPGAs in our electronic designs. The issue will be the size in relation to the current.
You are not the only one, I am pretty anxious for the end results as well.sign1I have no useful advice, but this is a very fascinating project. I am definately looking forward to the end result.
Best of luck.
That is a good point. :cry:I think the zener is the wrong device because it regulates when reverse biased.
Thanks for the clearification. It makes sense but does not seem practical, I am glad there are people around to figure this stuff out.:yep:DCC works by DC pulse width modulation, not voltage levels. DCC pulses to the motor are typically 12-14 volts, with pulse duration controlling speed.
So basically just find a speed that I want it to run at and it would run at one speed and work as an on/off switch like Russ was refering too?Looking at the options - how practical would fixed voltage operations be instead of controllable? If you could arrive at a reasonable speed at a given voltage, that fixed voltage reduced from track power would be more easily achieved with a simple circuit.
I debated on doing that and using the existing circuitry from the r/c car but figured it would be either too difficult to get it to recharge from track power, or it would be too inconvenient to have to take it off the layout to charge it every few minutes.I'd suggest battery power, but that would be even more space consuming, especially if a recharging circuit was added.
