You can plainly see the cracks in the bends, but I have a fix for that after the fact, and it involves a laundry marker. I had to get rid of Ron's excellent rings behind the nacelle cap due to the room of the electronics and substitute bonded computer wire painted with a laundry marker. The petals at the bottom of the jewel and electronic are now folded over and glued to pressure fit into the nacelle, I might glue or leave accessible depending on how tight the fit is. The jewel electronics turn on/off by twisting the bottom of the assembly where the petals are. Since the batteries will need changing I might just leave it unglued.
