Buck Rogers Land Rover
Sky Seeker
Well Established Member
Jun 1, 2015
1,178
1,083
95
A few props were designed and built for Buck in the first place and then repainted for BSG, too, because BSG got too expensive and Buck had a fresh budget. The EDD rifle and the Pumpkin shuttle (mockup & model) were two of them. The rifle and the matte painting of the space port from "Plot to kill a City" were later re-used in Star Trek: TNG.
Wow! Didn't know about that little fact about Star Trek! Too cool!
Sky Seeker
10,001
Draconian Rover unfolded and ready for testing! This time it's only four parts pages. ;)
I am ready for doing the BETA test build for you!
Next update: Land Rover Mk II has been unfolded and recoloured; some lines have to be tweaked a bit but it's looking great so far. :)
I am looking forward to seeing this one come together as well!
12,457
Short sitrep: First test build of the Draconian Rover discarded. The base colour was too light. New build with a darker colour will commence this eve (gotta get new "yellow" first ;) ).
12,457
http://memory-alpha.wikia.com/wiki/...ran_II_in_Buck_Rogers_in_the_25th_Century.jpg
source: http://www.ditl.org/Images/G/GuinanGun1.jpg
9229deb80f8ee5d464ab0ca373d118ee43b218b1f679e1cf96cdf3a03b69a1af_medium
Reactions: Sky Seeker
Lee Clifton
Wisdom and Kindness, A Zealot Sage
Oct 7, 2015
268
173
40
71
I will really have to build one of these and the StarFighter now. I've been on vacation this week and found one of the 8 inch Buck Rogers figures, in uniform with helmet, still in the box for only $25.00.
12,457
OK, here they are: :)
The basic layout is almost identical, however, there are fewer parts and the whole chassis is shaped like a box.
Let's begin with the parts for the gunner station.
This is the first prototype. The colours have been revised. Please take a look at the next post. ;)
12,457
Since the colours were much too bright I corrected this and proceeded with the revised version. Here are two images which illustrate the difference:
Revised gunner station - in colour!
Looks much better. :cool:
The skeleton fits perfectly - no glue required.
The wheel box covers:
They are attached before the chassis is closed. So you have enough room to hold the parts in place and apply pressure to them while glue is curing.
12,457
The chassis box is closed:
The wheels and treads consist only of a stylized compact version since the covers do not allow a clear view at them. And detail-building something you don't see is somewhat illogical. :)
Next: The turret. :)
12,457
The turret. Prepare yourself for the fiddly bits! ;)
I did not use the paper parts for the swivel joints but toothpicks instead. The paper rods (parts 25 & 28) are in the kit for you to determine the length of the rods and to actually use them on larger-scale versions.
The handles.
A few bits and pieces later...
10,001
The Draconial Rover looks FAN(FRAKKING)TASTIC!!!
I am thinking of using (paper) Q-tip handles instead of the toothpicks (so long as they are not too big for such).
Thank you for the templates. I will jump on the BETA build ASAP!
I am looking forward to seeing the MK-II build as well.
