X4 Building tread
Discussion in 'Aircraft & Aviation' started by Billy Leliveld, Jan 27, 2007.
  1. Billy Leliveld
    Billy Leliveld Member
    New round, new prizes...
    I 'm starting a new build, and I picked the Papertade X4
    A bit chauvinistic, because it's designed by Cor van Haasteren and published by Papertrade, and they're both Dutch, like me.
    The kit is in 1:24 scale, but the original plane was quite small, it looks a bit like a Halinski or Orlik model, lots of parts and lots of detail..
    gonna take a some time...
    Cheers Billy
  2. josve
    josve Active Member
    Seems like this is going to be an interesting build Billy!
    Looking forward to see more!
  3. Alcides
    Alcides Member
    After your last builds I'm wait to enjoy another masterpiece. :wink:
    Is this a donwloable kit? Where I can get one?
    Thanks
    Alcides
  4. Billy Leliveld
    As far as I know it's not a downloadable kit.
    I bought it from the Dutch publisher;http://www.zeistbouwplaten.nl/
    It's also here;http://www.e-papermodels.com/index.php?page=2&sort=2a&cName=aircraft-modern-aircraft
    If you are going to order it, The instructions say that the canopy of GPM for the 1:33 F16, with a little cutting fits to this model, I've got it as a nice side -order..
    Cheers, Billy
  5. Billy Leliveld
    Excelent fitting, this is a precision model..
    BTW is there a moderator who can put an "h" in the title of this thread,you can edit your posts but not the title..
  6. Billy Leliveld
    Here's the longitudinal bars..
  7. Billy Leliveld
    The first parts of the hull..
    Dry fit 10 times till it fits perfectly
    They leave you the choice of building it without the interieur, but why hurry?
  8. Billy Leliveld
    Here's the website of the guy who designed this X4.
    he also designed the X3 and the YB 49 Flying Wing, I've build them both, they where the most defying models I've ever build, but they're beautyfull.
    There are some free-bee's too,
    http://www.dioramix.com/
    Cheers, Billy
  9. Billy Leliveld
    It was not clear which parts I had to cut from the ribs and fuselage, so I'm building the cockpit interieur first, so I can figure it out..
  10. Billy Leliveld
    It already starts looking like a plane
  11. Clashster
    Clashster Member
    Very nice, Billy! Nice smooth lines! This looks like a great kit! Thanks for the posts!
    Chris
  12. Billy Leliveld
    Challenging, the belly of the fuselage is just one part..
  13. Billy Leliveld
    Lots of dry fitting, but after one hour it's on
  14. Billy Leliveld
    not that much progres, but the tail is on, and it's weekend...
  15. milenio3
    milenio3 Active Member
    Very nice colors, Billy. Making great progress on this build. Thanks for sharing.
  16. Bowdenja
    Bowdenja Active Member
    Very good build Billy................ I got this one when Lighthouse called it quits. I love this little X plane.
    Kepp it coming it might just make me want to cut this one up and have a go at it!
    john
  17. Billy Leliveld
    This little thingie goes inside the air intake
  18. Billy Leliveld
    Like this, nice detail
  19. Billy Leliveld
    When I wanted to do the wingsurface , I found out I made a mistake,(RTFM) the parts of the body at the wingroot should not be glued to each other, but to the upper and lower wingsurface,so I had to cut it loose, with a little bit of fumbling I managed to get it right
  20. Billy Leliveld
    Little bit of cheating, because the surface of the wing root was a little damaged I patched it up with a piece of normal printing paper
