WWII M1A1 Thompson smg
Discussion in 'Gallery & Designs' started by Nothing, Oct 28, 2008.
  1. Nothing
    Nothing Longtime Member
    i didnt feel like build today, so i started the conversion to the 1931 version. i started with the receiver first.
  2. Nothing
  3. Stev0
    Stev0 Active Member
    Seems to be the M1928A1 ... the A1 lost a couple of features including the rear peepsight guards.
    I like it though. I saw people blurting out that they wanted to see a 'Tommy-Gun' style with the Drum magazine and vertical forward handle. Meh. Sgt Rock used a stylized M1 that excluded the rear stock.
    You should try your hand at the MP40 and a Sten Gun mk II. I would assume the latter would be the easiest to design.
  4. Nothing
    you are right stevo it is the 1928a1. i was thinking of something else when i posted.
    heres some more work.
  5. Nothing
    ok i think im done with the conversion.
  6. Mousemuffins1
    Mousemuffins1 Member
    Awesome. So you are just going to simulate the fins then?
    I second the motion for an MP40 and sten MkII. I have your 1851 colt and derringer and am most impressed.
    I guess i'll just have to dream about an Owen gun though. :oops:
  7. Nothing
    i think you are talking about the ribs on the barrel. i think trying to physically build all the ribs would be extremly tedious to say in the least. although you could laminate strips. ill have to think about that a bit.
  8. Nothing
    test build update
    test build is going smooth.
  9. Stev0
    Stev0 Active Member
    I would seriously consider from internal reinforcements for these models.
  10. Mousemuffins1
    Yes, internal reinforcement. lets face it, they're guns. somebody's gonna play with them. :mrgreen:
    and yes, the ribs. I guess it would be about 25 variously sized rings to slip over a central barrel, perhaps? alot of cutting I guess, maybe you could offer it as an option for the more enthusiasticly inclined?
    Oh, and it may be just me, but I think the ejection port is a bit shallow, and should come down almost as much again on the side.
  11. Nothing
    got a bunch more done. reworked some stuff. but im pleased with how this looks.
  12. Mousemuffins1
    awesome awesome awesome!
    The Gunport shape can be seen easily Here:
    [​IMG]
    hope that helps.
  13. Nothing
    mousemuffins i know what youre sayin but sometimes a mesh gets to a point where moving verts around can throw everything outa wak. i have come very close to trashing this design because of that very thing on some other areas i was trying to correct. as it is right now it works. a bit small maybe but a good representation. i am very happy with the results, and with the time spent on this i am not going to jinx it by mucking around in the mesh some more.
  14. Mousemuffins1
    fair enough. I've no idea how these programs work, I asumed it would be easy. Beautiful nevertheless.
  15. Nothing
    sometimes it is easy and sometimes not. i had some other areas i needed to change and thought the adjustments i made were simple but totally changed the model geometry. then had to undo and redo etc. the ejection port actually has a lotta verts that span 2 parts. im not the best mesh weaver so i am at this point gun shy(no pun intended) to further edit the model.
  16. Nothing
    i did go in and try to adjust it. but moving the port edge down changes the bolt opening. i just dont want to take a chance on having the mesh go loopy.:(
  17. Nothing
    ok next decision. the wood textures up close are pixilated. but hold it out and it looks very realistic. do i keep it or use this?
  18. Nothing
    well all the screwing around with mesh has left me in a bind(as i expected it would) so the built version is what im going with. i try to incorperate the points in the second version.
  19. DarthPineapple
    DarthPineapple Member
    Wow. Will this model be for free or sold? I'd love to get one. :eek:
  20. Mousemuffins1
    Your efforts are appreciated. Whoda thunk it be so difficult? I'm a tad embarrased now. anyhoo, the second wood texture looks great.
