Working on the MDC shay
Discussion in 'The Academy' started by Ray Marinaccio, Nov 27, 2003.
Thread Status:
  1. Ray Marinaccio
    Ray Marinaccio Active Member
    To make the brakes I formed the shoes from copper wire and hangers from steel wire.
    After the shoe was formed as shown in the photo it was soldered, filed to shape then formed to the contour of the wheel.
    The shoe was installed on the hanger, then the end of the hanger was soldered.
  2. Ray Marinaccio
    Holes were drilled in the sideframes and gearbox,then the hangers were glued in place. The wire extending from the shoe was glued onto the gearbox then a piece of H-beam glued to them.
  3. Ray Marinaccio
    A side view
  4. Ray Marinaccio
    I sprayed the basecoat on today.
  5. Ray Marinaccio
    The motor looks a little better with paint.
  6. Ray Marinaccio
  7. Ray Marinaccio
    I expect a little weathering will bring out the wood grain on the pilot beams.
  8. Ray Marinaccio
    Rear view.
  9. Ray Marinaccio
    Thanks Chris and Stu.
    I'm getting anxious to run this locomotive.
    As with most of the locomotives I build, its just for the pleasure and satisfaction of doing it.
    I added decals today I couldn't decide on a company name so I just numbered it , added builders plates and decal stripes around the windows. The bell, whistle and headlight rings were painted with a gel pen. Then it was clear coated and a light dusting of chalk was added.
  10. Ray Marinaccio
    I need to do a little fine tuning on the trucks (wheel chatter at low speed) and install the lights. Otherwise its ready to bring some logs off the mountain.
  11. Ray Marinaccio
    I'll get some better photos later
  12. Glen Haasdyk
    Glen Haasdyk Active Member
    Beautiful work, If I ever get a shay I'll be sure to remeber your work. Maybe I can use your tips on electical pickups on my MDC climax. It's drivetrain is in need of refreshing.:wave:
  13. Ray Marinaccio
    Thank you Glen and welcome to The Gauge.
    I have an old MDC climax drive, But haven't done anything with it yet.
    If you have any questions , there are others here that have experience with them that are willing to help, Just ask.
  14. 60103
    Ray:
    I really like the thread. When I get my new ink cartridge, I'll print it out for reference.
    I bought a shay about 20 years ago, when they were new. All I've done to it so far is sonic scrub the metal castings.
    I can't really figure out what you did with the brakes, despite your pictures. The finished product looks so much better than the bent paper clips in the picture. :D
  15. Ray Marinaccio
    Thanks David,
    I'll have to see if I have some better photos of the brake assemblies. They were a bit of a pain in the butt, but I thought the trucks looked a little bare without them.
  16. Ray Marinaccio
    I couldn't find better photos so I made an oversized assembly that is easier to see.
  17. Ray Marinaccio
    A closeup of the shoe.
  18. Ray Marinaccio
    The gaps were filled with solder.
  19. Ray Marinaccio
    Then filed to shape.
  20. Ray Marinaccio
    The shoe was arched and the face filed to the contour of the wheel. The hanger was threaded through the shoe then mounted in holes drilled in the side frame and gearbox.
    The H beam was then glued to the arm on the shoe. Some material needed to be removed from the H beam to clear the universals.
Thread Status:
