Weekly Foto Phun 10/10-10/16
Discussion in 'Photos & Videos' started by jesso, Oct 10, 2008.
  1. jeffrey-wimberl
    jeffrey-wimberl Active Member
    The new crossover is for the most part done. Scratch another project off the list.
    [​IMG]
  2. Catt
    Catt Guest
    This'n is the running mate to the B&O unit I posted on page 4 last week
    [​IMG]
    This is the b unit that will go between them.
    [​IMG]
    Current paint scheme plan is ACL purple and silver.
  3. chessie4155
    chessie4155 Active Member
    Waiting on a train on Depot street:
    [​IMG]
  4. GN.2-6-8-0
    GN.2-6-8-0 Member
    GN.2-6-8-0 number 1973 simmers quitely while awaiting it's train along with Caboose number 271
      File size:
      176.7 KB
      File size:
      143.6 KB
      7
      File size:
      174.4 KB
      File size:
      181.6 KB
  5. jeffrey-wimberl
    Chessie: I immediately recognized the name on the building the Pinto is parked in front of. I learned a lot from Wayne.
  6. UP SD40-2
    UP SD40-2 Senior Member
    GREAT SHOTS/WORK POSTED THIS WEEK FOLKS!:bravo:
    [​IMG]
  7. CCT70
    CCT70 Member
    What do you have left Doc?
  8. TrainNut
    TrainNut Ditat Deus
    Hmmmm, we bought a new camera today and I thought I'd play around with it and see how it worked. First up, a shot down Turtle Lane just as the steamer thunders through.
    [​IMG]
    It appears I need to play some more with the foreground focus.
    Next up, I thought I'd share some extreme closeups of projects which I hope to make some headway on this week -
    My HOn3 gondola needs some grab bars and other detailing...
    [​IMG]
    Here are a couple shots of my two structures from Mooreway...
    [​IMG]
    I'm not entirely tickled with the yellow and may change it to white with brown trim like the one below. This little building is a whole whopping 1-1/8" by 7/8"!
    [​IMG]
    This kit did not come with porches and so I decided to add some. I'm also not happy with the roof and still need to give it some attention like the little yellow building above.
    Last up, I found this roundhouse at a swapmeet for $5. I've been wanting to experiment in this area for a while now but as you can tell by the layer of dust on the turntable, I have not been able. The roundhouse will undergo severe modifications. First, if you can't tell, the roundhouse was built for a bigger turntable. I've got an idea on how to fix that though. Second, I plan on hacking the rear half off as there will be a mountain directly behind the roundhouse and I don't have room for the whole thing. I'll try and document this area as I proceed.
    [​IMG]
    Seeing these pictures has shown me that if I continue to take pictures this close up, I am going to have to take my detailing to a whole new level.
  9. Catt
    Catt Guest
    KP&W covered hopper 28755 headed to Gilbert Grains elevator on the tail end of a GVR grain special.
    [​IMG]
  10. jeffrey-wimberl
  11. nachoman
    nachoman Guest
    Jeff, that billboard on the right seems like a good place for that trooper to set up a speed trap, especially if the gas station on the left sells doughnuts :)
    Kevin
  12. jbaakko
    jbaakko Active Member
    Here's some new units I've been working on.
  13. chessie4155
    Sorry Jeffrey but I dont think we know the same person..This was named after my buddy Steve.
  14. jeffrey-wimberl
    Ok. I was thinking of Wayne Wesolowski. He's written quite a few books on model railroading and has several videos available from Kalmbach Publishing. One of the videos I have is the Basics of Model Railroading. I picked it up back in the mid 80's. He has two sons, Tony and Steven.
  15. csiguy
    csiguy Member
    very nice jesso. also im interested as well where you got the masking tape.
    todd
  16. doctorwayne
    doctorwayne Active Member
    If you need masking tape of a particular width, simply cut it to suit from a wider tape.
    To do this, peel off a suitable length and place it, sticky side down, on a clean sheet of glass. Use a straightedge to ensure that it's placed straight on the glass, with no curves or wiggles. Using a fresh blade and a steel straightedge, trim one or both of the factory edges - these often become nicked and dinged by handling, and also pick up dust and fuzz from the air. Also, if the roll has been sitting around for some time, the adhesive along the edges tends to dry out somewhat, leaving the edges less sticky than they should be for a good seal along the masked line. Working from the trimmed edge, use dividers to mark off the required width(s), then a sharp blade and straightedge to make the cuts. You can also layer the lengths of tape on the glass before trimming, allowing you to cut multiple strips with a single pass of the blade.
    Wayne
  17. CCT70
    CCT70 Member
    sign1sign1sign1sign1
  18. jeffrey-wimberl
  19. TruckLover
    Now that is a useful bit of information Wayne :mrgreen: :mrgreen: :mrgreen:
    Hmmmmmm, this gives me an idea, get some yellow and white Electrical Tape and cut road and lane markings out of them :mrgreen: :mrgreen:. Ive tried other stuff that i bought from hobby shops (cant recall the MRF's name, but i used them on my CAT Rental Module) and it sticks for a day or so and then peels up in some spots, this is after i have completly wiped down the area and let it dry for the best and most ideal sticking surface lol. They just dont work, and for $8.00 a sheet, you think they would :eek:
    Im going to try the Electrical Tape thing out using Wayne's tip :thumb: :mrgreen:
  20. doctorwayne
    Josh, most tape "loses its grip" before too long, and I think that electrical tape applied flat (as opposed to wrapped around a wire) will fail, too. Why not use masking tape to mask the road for application of an actual painted stripe. You can make broad curves with the tape as it comes, or trim it into narrower strips for really tight curves and corners.
    Wayne
