Warhammer 40K Armour
Discussion in 'Science Fiction & Fantasy' started by FlareBaffled, Jan 19, 2008.
Thread Status:
  1. Sanginus
    Sanginus Member
    thanks for the great link, that's cool
    many things for everyday RPG/Wargame use :)
  2. Sanginus
    Sanginus Member
  3. Sanginus
    Sanginus Member
  4. ARMORMAN
    ARMORMAN FOUNDATION CORNERSTONE
    well caught!
  5. ARMORMAN
  6. Gidster
    Gidster New Member
    This looks fantastic!
  7. Gidster
    Gidster New Member
    YOU guys are simply amazing!
  8. Gidster
    Gidster New Member
    Anyone see any Arbiter flats out there?
  9. arkon
    arkon Member
    are there any paper dreadnouhgts outthere?
    thank you
    once i get better ill have a go at this one
    im building the original one right now, will try to post pics when im done!
    very nice!
    i started paper modeling with the intent of making my own r/c planes. i started with the fiddlersgreen models cause they were the first i found. i was planing on using one of the cheap little rc planes i can by at wal mart for the eletrics.but RW got in the way. after seeing this thread i hope to try again. will probly try to make an albatross dIV. thanks for the re-inspiration!
    i mostly give them away to freinds an the guys at work. i found it does not bode well for the modelcto hand it to my wifes 8 year old and say ' check out the paper plane i just finished". he promptly throws it into the ground and says" it does not fly good"
  10. ARMORMAN
    look through the tread before asking. There have been some dreads and killa kans posted.
  11. pastru79
    pastru79 New Member
    warlord titan
    hi this is my first post . I have found a 3d warlord titan plan. it come as a computer mod but you can open it with peparuka. you have to adjust the scale. I am building mine 60 cm high. i think it will be big enough. here the link. I think you have to register to have the warlord . just type robot in the search bar.
    http://www.turbosquid.com/Search/Index.cfm?keyword=warhammer
  12. MTK
    MTK Active Member
    Yes, I know. Don't applaud, just throw money. Thank you, thank you.. What? This isn't my thread? Doh! Sorry.:confused:
  13. japanfilipino
    japanfilipino New Member
    does everyone print on 8x11 card stock? or 8x14?
  14. Dangersaurus
    Dangersaurus New Member
    Probably depends on location. I personally print on 8.5x11 card stock, but many templates that originate in Europe are designed to print on A4 paper.
    8x14 would be handy, but I haven't seen it in the shops I go to.
  15. ARMORMAN
    I end up redoing layouts for Elli's kits to fit 8.5 x 11.
  16. JHSurf
    JHSurf Member
    I was at Hobby Lobby today and found some paper that is about the weight of 110# carstock (no weight given on the paper). It is called Tagboard and comes in 9x12" sheets and was only 9 dollars for a pack of 100. I havent used any of it yet but it looks like it should work well. Here is a link to it on Hobby Lobby's website...
    http://shop.hobbylobby.com/products/tagboard-113126/
  17. Tirick
    Tirick Member
    I actually open and reorganize each .pdf I want to use of Eli's in GIMP. Getting A4 is next to impossible where I am, and no one carries cardstock in 8.4x14. Takes maybe a half-hour or so, but completely worth it. It also allows me to duplicate elements that I know I will want to laminate.
  18. Newobmij
    Newobmij New Member
  19. Newobmij
    Newobmij New Member
    [​IMG]
    [​IMG]
    [​IMG]
    https://rapidshare.com/files/2469967552/stormravenfinal.pdf
    I'm the same guy that did the Dark Eldar Razorwing and Venom. There's a tutorial for the venom on pages 5 & 6 of the pdf here:
    https://rapidshare.com/files/1232477548/venomtemplate.pdf
    The Stormraven in the link is the third revision I've done of it. The turret is articulated, but the exhaust vents are just textured on to save time. I would have done some weapons options, but the lascannon variant without the hurricane bolters was all I had available to borrow to use as a reference.
  20. ARMORMAN
Thread Status:
