Warhammer 40K Armour
Discussion in 'Science Fiction & Fantasy' started by FlareBaffled, Jan 19, 2008.
Thread Status:
  1. ARMORMAN
    ARMORMAN FOUNDATION CORNERSTONE
  2. MTK
    MTK Active Member
  3. callyfergus
    callyfergus New Member
    paper thickness
    p51cho, I use either 200 gsm or 210 gsm card for my papertanks. On large surface areas that become flimsy (eg the large sides of the Thunderhawk), I used 1mm thick card for structural support.
    As i can't print on cardboard that thick, I only use 1mm card on areas that are large and easy to trace and cut out.
    Hope this helps.
  4. ARMORMAN
    That's why there's a file download link.... ;)
  5. Kjev
    Kjev Member
    I print it out, glue the paper part directly to the cardboard, and then cut it out. You can sometimes eliminate the tabs that way, since trying to fold cardboard SUCKS.
  6. papadenati
    papadenati New Member
    p51cho,I use 220g for everything (tanks,cars,bikes,flats,truks and everything you can imagine) but for cardboard parts I print on 70g and glue the paper on.:thumb:
  7. p51cho
    p51cho New Member
    thanks all for your replies as i said i have some 200gsm coming hopefully tomorrow so i will give that a go and let you know how it goes/went maybe even get some pics uploaded of my build
  8. silveroxide
    silveroxide Well-Known Member
    That Razor Wing looks good but does anyone have a build thread on it? The missiles have a great potential for enhancements as well as the other weapons load. I like it, and will attempt it as soon as I get some time off. In the meantime, I will browse and see others build it first.
  9. callyfergus
    This thread may prove promising in time as the designer may provide instructions.
    http://paperhammer40k.com/index.php?option=com_kunena&Itemid=30&func=view&catid=7&id=574
  10. callyfergus
    Stormraven (Blood Angels, Grey knights, blank)
    rapidshare.com/files/413483260/BAstormraven.zip
    Thanks for your patience callerfergus!!:thumb:
  11. Zathros
    Zathros Guest
    I put a hold on the attachment above but it seems O.K., if there is any complaints, then we'll remove it. Thanks!
  12. ARMORMAN
  13. Sanginus
    Sanginus Member
    Hi, thanks for the link, :thumb:
    are on sheet 2 and 3 are graphic errors in the first figure-present
    it will still give it a correction, or appears only in my case the error?
    and i can´t save files in right scale, only with right click "graphic save at"
    think thats too small ?
    :confused:
  14. papadenati
    Hi
    no Sanginus,the graphic error is not just for you.I have it to :sad:.
    But,thanks for the link Armorman :thumb:
  15. ARMORMAN
  16. Adalias
    Adalias New Member
    First off, this is the best thread ever, just thought I'd mention that right away :-D
    Also, I was wondering if there was any other necron stuff out there? I've already built a monolith, and I've seen the pylon, but don't have much use for one, so maybe some of those amazing model flats? Or some scenery?
  17. ARMORMAN
  18. ARMORMAN
  19. dadavejdr
    dadavejdr Member
    Woow:shock: the heavy mortar with trench is great.
    We(I) want more thinks like that.
  20. ARMORMAN
Thread Status:
