Walther Mkb.42 (need some help)
Discussion in 'Gallery & Designs' started by Major Walter Schmidt, Oct 17, 2008.
  1. Major Walter Schmidt
    Major Walter Schmidt Newbie Designer
    I am making a model of The Mkb.42(W) and has finished the stock.
    Im not sure what the part in the middle (the thing with the lighter colour behind the sight and on the top part of the rifle) Is it a saftey mechanism?
    Also, If anyone has any good pictures, that would be nice.
    A Big problem is I dont know how to do textures with 6KT (the 3d CAD that comes with Pepakura) so if anyone can help me, it would be most thankful.
  2. Major Walter Schmidt
    Oh yeah, and some pics of the stock.
      File size:
      11.4 KB
      356
  3. JT Fox
    JT Fox Member
    Another thread to watch.
    Cheers JTF
  4. Major Walter Schmidt
    I was making the trigger part but my PC just died:curse:wall1wall1
    gotta re-do...
  5. Stev0
    Stev0 Active Member
    Ah, the precursor to the MP43/44, STG44.
    Neat.
  6. cgutzmer
    cgutzmer Guest
    That spot you are talking about is where the spent shells eject :) it can also be manually pulled back in case it jams!
    Chris
  7. Nothing
    Nothing Longtime Member
    i dont use pep for for textures. you have to export the unfolded layout and apply textures in a paint program. unless you already have the uv maps set and need to set the textures that way? im not real clear on what you want to do in pep.
  8. Major Walter Schmidt
    more pics: Am now working on the barrel
  9. Stev0
    Stev0 Active Member
    Yeah that's the ejection port for clearing jams.
    remember folks, if it doesn't work, first rule of the military is smack it on the ground. :D
  10. Major Walter Schmidt
    More progress!
    From you guys' advice, I think I will add the texture with Illustrator or Photoshoppe afterwards.
  11. Major Walter Schmidt
    More progress on rifle.
  12. Major Walter Schmidt
    Guys, do you think I should do a "photographic effect" (like the remington derringer on ecardmodels) or a "Illustrator effect" ?
  13. Nothing
    i guess it depends on a) your reference pictures available and or b) what end effect you want to acheive. jan rukers terminater rifle is an excelent example of non photo realistic textures used to look realistic. his aliens pulse rifle is a good example of simple textures used to good effect.
  14. Major Walter Schmidt
    Thanks nothing!
    I think I will try what I can and see what works best.
    *my 3D model compared to photo*
  15. Major Walter Schmidt
    More!
  16. Major Walter Schmidt
  17. sidewinder81777
    sidewinder81777 Midnight Modeler
    What ever happened with this project?
