Voltron return
Discussion in 'Gallery & Designs' started by Kezn, Feb 25, 2009.
  1. Flame3230
    Flame3230 The Chuck Norris of Tuba
    Ok, I have completed Voltron's toe, so I am moving on to the leg. But I have pictures of the stages every once in a while.
    [​IMG]
    As you said, that section needed to be thicker, and my A4 paper is an average thickness, and feels paltry after using 32lb paper. So what I did was use a glue stick and glue said sections to a piece of my thick paper. Once I glued the sections together, it became insanely thick, but it fufilled its purpose.
    [​IMG]
    After I glued the sections together.
    [​IMG]
    Side view, where you can guess at its thickness.
    [​IMG]
    The Bottom, everything didn't line up perfectly, but I made due.
    [​IMG]
    The front view of the completed toe.
    [​IMG]
    Side view of the toe.
    I also reinforced and weight-bearing areas on the model, mainly the bottom and back to prevent it from caving in at any point. This is very large, about 3 or 4 inches long, and aboutthe same tall. So, I'm already at work on the lower leg, so I hope to post my progress again soon.
    EDIT: Forgot to resize the pictures, but it's fixed now.
  2. Kezn
    Kezn pwned in the dawn
    hi Flame,
    good jobs. i think i was wrong on the nose, it should be black. and you need to glue some paper inside the face so it resemble the moustaches.
    also i finished making kit for the thigh, i ll send it to you.
    wait to see more.
    Kezn.
    @: for the hips i think if i wanna make it moveable, i need to divise the hips by 2 and add it directly to the thigh..
  3. Flame3230
    I was wondering about the nose because it was a different color in the pdo than in the pdf, but I will work on the face some more, and in the meantime, I am done with the lower leg besides detailing, so pics will be here fairly quickly.
    EDIT: Lower leg is done minus detailing, and the toe is attached. I am working on the upper leg now, then detailing will follow. But here are pictures.
    [​IMG]
    Side view of the lower leg. It is very large, about half a foot by my guess.
    [​IMG]
    The foot of of this model is as big as my hand, and looks like the model will be enormous.
    [​IMG]
    And finally, a back view.
  4. Kezn
    nice work flame,
    i send you the right leg kit.
    do you receive it yet ?
    Kezn.
  5. Flame3230
    Yes, I've got the right leg, and once I finish with the left, I'll start on the right, which should be soon.
  6. allhallowseve
    allhallowseve Member
    Any new pic's or update's ...
  7. Kezn
    hi allhallowseve.
    we are now in full periode of graduate examens. I ll done with my bachelor in the next 2 weeks. so please be patient until then :D
    I really want to finish making Voltron right after my examens. It been for too long !
  8. allhallowseve
    Way to go !! on your degree ...
  9. Kezn
    hi guys,
    a small update, since i'm free this afternoon :D
    this is the back of thigh.
    [​IMG]
    [​IMG][​IMG][​IMG]
    Kezn.
  10. Flame3230
    Sorry that it's been so long since an update, but I have had some problems. It started out with my printer causing problems, and then we had a lot going on, namely finals, cramming 3 weeks of school into 1 and a half weeks, etc... So I am still where I was at the last update, except teh seperate pieces are attached, so all that is remaining is the detailing. As for other bad news, I have a job this summer at a camp, and I will be gone for an entire month, so Voltron will be on hold until I return. I will, though, work on it as much as I can until I leave.
  11. Namrepus221
    Namrepus221 New Member
    DAMN! This is AWESOME.
    I wanna build this thing... full sized too.
  12. Flame3230
    Epic late, but I am starting to make some real progress on it
