Viper MK ll, Ninjatoes, painted blake 7.
Discussion in 'Science Fiction & Fantasy' started by Dagger, Mar 7, 2019.
  1. Dagger
    Dagger New Member
    Greetings. After 8 years modeling on paper it was time to do something in this category. The Viper is in first place in my preference, Galactica fan this ship fascinated me when I saw the first chapter of the original series, far away a long time ago .Download 5 of the repainted blake 7 from Ninjatoe's.The first is the version of the US Navy. Some considerations of the model, fits quite well, good shape, robust, is not difficult, very nice to build. The most problematic is see where to cut and fold certain parts, the lines are not very sharp. The repainting is very beautiful up here. My construction, I would say acceptable. I expect criticism, suggestions and tricks to improve. First photos of the assembly. 20190222_213424.jpg 20190223_230035.jpg 20190224_102118.jpg 20190224_211138.jpg 20190224_223225.jpg 20190224_224517.jpg 20190226_190936.jpg 20190226_192425.jpg 20190226_192439.jpg 20190226_193133.jpg
  2. Dagger
    Dagger New Member
  3. Dagger
    Dagger New Member
    Más avances. 20190227_183619.jpg 20190227_223220.jpg 20190228_214822.jpg 20190302_055015.jpg 20190302_055028.jpg 20190302_163142.jpg 20190302_224631.jpg 20190303_112244.jpg 20190303_113243.jpg EnEnEnEnEnEnEnEnEn
  4. Dagger
    Dagger New Member
    Turbina central y timón. 20190303_122244.jpg 20190303_164627.jpg 20190303_215508.jpg 20190304_213051.jpg 20190304_213141.jpg 20190304_213155.jpg 20190304_213258.jpg 20190305_202955.jpg 20190305_203005.jpg 20190306_054443.jpg
  5. Dagger
    Dagger New Member
    Turbinas laterales. Sólo quedan alas y cañones. Muchas gracias. 20190305_214201.jpg 20190306_125043.jpg 20190306_140813.jpg 20190306_195722.jpg 20190306_195837.jpg 20190307_105511.jpg 20190307_105523.jpg 20190307_105532.jpg 20190307_105545.jpg
  6. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    You are doing a great job on this project.
  7. starbuck
    starbuck Active Member
    If I remember right this is not the first version of a modified viper done by you.
    Perfect as always.
  8. Dagger
    Dagger New Member
    ¡Muchas gracias a todos! Starbuck, agradezco tu comentario, en realidad es mi primera construcción en esta categoría, tal vez me confundas con otro colega. Saludos. Alas y cañones. Con varios pliegues, mi error aquí no fue reforzar con cartón, ya que tienden a deformarse. . Los cañones con papel fino simple son tubos y conos finos. 20190307_170216.jpg 20190307_192717.jpg 20190308_221058.jpg 20190309_215126.jpg 20190310_075813.jpg
  9. Dagger
    Dagger New Member
    El fin. Una construcción muy divertida, perdón por los errores, creo que solo soy un constructor de nivel medio. Creo que con un trabajo adicional, este diseño se puede mejorar mucho, como hacer el interior de la cabina, la cubierta transparente, el tren de aterrizaje y algunas otras cosas. Un muy buen diseño, bonito y divertido. Y con todas las versiones que Blake 7 nos da, Starbuck puede tener su propio circo volador como el Barón Rojo en su tiempo. Ya tengo mi primer Viper, ahora podemos salir y defender la flota de los Cylons malvados. Muchas gracias. 20190310_161948.jpg 20190310_161958.jpg 20190310_162116.jpg 20190310_162134.jpg 20190310_162448.jpg 20190310_162500.jpg 20190310_162532.jpg 20190310_162559.jpg 20190310_162716.jpg 20190310_162641.jpg
    blake7, Sky Seeker, zathros and 5 others like this.
  10. spaceagent-9
    spaceagent-9 Right Hand Man and Confidant Moderator
    Pretty slick!!!
  11. bigpetr
    bigpetr Designer/Master Modeler
    It is a pretty:).
  12. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    This looks awesome! A very fine job! :Congrats::Congrats::Congrats:
    Dagger likes this.
  13. Gandolf50
    Gandolf50 Researcher of obscure between war vehicles... Moderator
    :iagree::iagree::iagree::Bravo:
    NICE JOB!! Thanks for sharing!!
    ¡¡BUEN TRABAJO!! Gracias por compartir !!
  14. zathros
    zathros -----SENIOR---- Administrator Moderator
    Utilice Google "Translate" para publicar en inglés, todas las publicaciones deben tener un equivalente en inglés, no tiene que ser perfecto. ¡Gracias!
    Use Google "Translate" (https://translate.google.com/ ) to post in English, all posts must have an English counterpart, it doesn't have to be perfect. Thank You!
    Use un rotulador de punta negra para rellenar los bordes o las partes negras para que no se vean blancos. También puede recortar los paneles de las ventanas y utilizar plástico de color oscuro, de lámina de plástico pintada en la parte posterior, para obtener un efecto mucho mejor. Lo que has hecho es muy directo y verdadero, a veces las personas no se toman el tiempo para hacer que los modelos sean rectos y verdaderos como el tuyo. ¡Muy bien hecho! :)
    Use a Black tipped felt pen to fill in the edges o the Black parts so no white seem shows. You can also cut out the windows panels, and use either dark colored plastic, of plastic sheet painted on the backside, to give a much better effect. What you have made is very straight and true, sometimes people don't take the time to make models are straight and true as yours come out. Very well done! All your models are built to a very high standard . :)
  15. Dagger
    Dagger New Member
    Thank you very much everyone for watching, commenting and advice and suggestions. Sorry if the text was not translated, I hope that if I have problems with the translator, I do not know why, although I copy the translated text, I change it back to Spanish. .Regards.
  16. Sky Seeker
    Sky Seeker Well Established Member
    Great Job! :bowdown::bowdown::bowdown::bowdown::Bravo::Bravo::Bravo::Drinks::Drinks::Drinks:thumbsupthumbsupthumbsup
  17. Dagger
    Dagger New Member
    Greetings.Second Viper at the request of one of my nephews who chose the black Police Caprica. In this beautiful design I will try to add some extra details. In this design you can reform several things, add others, which I think can make this model look better. if it's already very good. The beginning: front part of the fuselage. What is different here is that the holes in the RCS are in order to give it some depth, it does not differ much in the photos. The second thing was to cut the parts where the sensor systems are and communications.Aqui if you notice a change.Before going to close the rings cut to a certain limit, close and then finish cutting. 20190427_130456.jpg 20190427_132142.jpg 20190427_151329.jpg 20190427_172747.jpg 20190427_201715.jpg 20190427_213616.jpg
  18. Dagger
    Dagger New Member
    After removing these parts stick them in cardboard of 0.5mm, built the frames in 1mm and place them inside. I see it well, it shows a change with respect to the original. Later on we will have to reform something the formers to fit well. 20190427_213622.jpg 20190427_214832.jpg 20190427_215658.jpg 20190427_221337.jpg 20190427_223722.jpg 20190427_230511.jpg 20190427_230609.jpg 20190427_231033.jpg
    Sky Seeker likes this.
  19. Dagger
    Dagger New Member
    We complete the fuselage. 20190428_161348.jpg 20190428_163204.jpg 20190428_202216.jpg 20190428_203654.jpg 20190428_203705.jpg 20190428_211827.jpg 20190428_220229.jpg 20190429_171128.jpg 20190430_133810.jpg 20190430_142347.jpg
  20. Dagger
    Dagger New Member
