USS Enterprise NCC-1701-D
Discussion in 'Science Fiction & Fantasy' started by Enterpriserft, Jan 4, 2009.
  1. Enterpriserft
    Enterpriserft Member
    Howdy..
    I have just finished making Clever's awsome Enterprise-Dbounce7!
    BTW, if anyone knows more Enterprise-D Paper models, you are free to inform me.. for example that one in the webshots.. I'm not able to download it but if someone could send it to me, I would be pleased..
    Anyway, here's the ''big D'':
  2. wow your builds are so clean have you tried zoushos enterprise e. also were did you get that MSD (Master system display) of the enterprise in the backgorund. and i may have the e from the webshots album ill have to check it may be on my other PC
  3. Enterpriserft
  4. thank for the link and i look for the webshots enterprise d for you i lnow it somwere on my othe pc if you pm me your email address so i can send them to you when i find them
  5. Enterpriserft
  6. D-WHALE
    D-WHALE Utopia Planitia Engineer
  7. Enterpriserft
    Thanks, Marko!
    I had a little trouble with saucer section phaser banks and I couldn't get them as they should be so I just drew them on. And Deflector is also little bit changed, but otherwise, great stuff!
  8. D-WHALE
    yeah, the phaser banks:oops: I could not change that, because i had not the original texture map files! the best way is to glue the phaser banks on the saucer before you glue the upper and the lower half together! Anyway! i think it is the best D in the Net:mrgreen:
  9. trekman1017
    trekman1017 Member
    you are an amazing modeler
  10. Enterpriserft
    Thanks! I guess I just have so much experience cos since little boy i've made all kind of models out of cardboard.. Actually if you just wait a second I'll put some pics of my Type-15 Shuttlepod ''Onizuka'', which i've made all by myself, following closely blueprints..
  11. mchale
    mchale beach boy
    i like it lots its interesting to do paper models i started out using legos then plastic now paper it's fun my step brother thinks paper models are gay
  12. Paragon
    Paragon Active Member
    I've got the Webshots 1701-D if you want it. I've also got it scaled up to 1:1900 if you want.
  13. Enterpriserft
    Thanks for that webshots D!
  14. trekman1017
    trekman1017 Member
    If you try the Enterprise -E again P.M. me, i acurized the deflector
  15. Enterpriserft
