Union Pacific BIG BOY 4-8-8-4 1/48 Scale
Discussion in 'Gallery & Designs' started by kooklik, Feb 20, 2008.
  1. kooklik
    kooklik Member
    It was very difficult to hang the links to leaf springs from bottom side. Especially coil spring unit is small and easily to be fragiled. For more easier to do suspension , assembly from top side is a way to solve problem. I think I should separate the chassis and tank. I'll do later on the beta-building version by volunteers.
    Coil Spring Unit
    Assembly
  2. Elliott
    Elliott Senior Member
    Magnificent work, Kooklik! The train guys must be drooling over this. I don't know how you keep getting better but you do.
  3. kooklik
    kooklik Member
    Suspension unit completed
  4. kooklik
    kooklik Member
    Milliped wheel brake and link.
  5. MadHatter
    MadHatter Charging at full tilt.
    Oh my GREATNESS!! I can't believe this is being done- out of card even!
  6. kooklik
    kooklik Member
    All brake sets (total 20 sets)
  7. kooklik
    kooklik Member
    First brakes assembly. The brake rod is made of 1.4mm copper wire (same as coil spring).
  8. kooklik
    kooklik Member
    All brakes on chassis.
  9. kooklik
    kooklik Member
    Hi to all
    I've just come back from short leave. Nothing much inprogress. I re-designed the tender truck frame. The old one was rather weak. I found this problem during tender millipede wheels building. I changed all paper thickness to be cardboard. It's so good result. The wheels & bearing aligment is exactly good.
  10. kooklik
    kooklik Member
    Hi there
    I'm back to the thread again. Added wheels and leaf and coil spring. It's not well finished yet. I checked each part aligment. All of them well fit as well as the digital model.
    BR.
    ----kooklik----
  11. cgutzmer
    cgutzmer Guest
    superb! Thanks for the update :)
    Chris
  12. N Gauger
    N Gauger 1:20.3 Train Addict
    That looks great!!!! :D :D :D :D
  13. cauesousa6
    cauesousa6 New Member
    :inw::inw::inw::inw::inw::inw:jawdropjawdropjawdropjawdropjawdropjawdrop stuning work, i want to buy one :mrgreen:
  14. kooklik
    kooklik Member
    Hi to all , thank you
    I finished the right side brake. A difficult and complicate section. Some joints are very small and weak. I must apply superglue to reinfoce them.
  15. kooklik
    kooklik Member
    Brake completed !
  16. shaygetz
    shaygetz Active Member
  17. Nothing
    Nothing Longtime Member
    i am stunned every time i visit this thread!!
  18. JT Fox
    JT Fox Member
    Me too. I haven't posted on this thread before, (or the sub thread for that matter), as I am simply lost for words.
    Cheers JTF
  19. kooklik
    kooklik Member
    Thank you for all kind words. Hope you still enjoy with the Bigboy's growing up in slow speed of progression.
    Just small addition today.
    **Assembly another side of brake in rough step.
    1.Pre-Assembly parts
    2.Moving Rods Set with hanger (small piece on the rod)
    3.Then brake cylinder
    4.Completed brake
    **Addition for coil spring guard plates
  20. Elliott
    Models within models. Beautiful work Kooklik!
