U-Don's Lunar Module - Progress shots
Discussion in 'Space & Aeronautics' started by rlwhitt, Oct 9, 2006.
  1. rlwhitt
    rlwhitt Active Member
    I started the LM over the weekend and this is the progress so far. Overall I'm quite happy with the fit of things, and it's gone together pretty well. I did run into a couple of snags worth noting:
    One is that there is a framework of cross pieces inside the descent stage body that is shown in photo 5 of instruction page 10. Maybe I really messed something up badly, but this would not come close to fitting for me. In frustration, I threw it out and scratch-built a couple of frame pieces of my own.
    The other glitch is the engine bell on the ascent stage. Some of the parts in this kit get printed on both sides, for example so that the main engine bell gets dark color on the inside. The ascent engine bell was not so treated therefore would turn out white on the inside. I could of course just have colored it in with marker, but decided it would be better to do it right, so I made a reverse page for this one in the manner the author did for the others. I'm going to attach the resulting PDF file to this message for anyone else who wants it.
    Now for some pictures! Click on the thumbnails for larger versions. First are the basic large pieces that I've completed. The "face" piece is not quite done and cleaned up here, but you get the idea:
    [​IMG]
    Next is a close up of the ascent stage main body. This is an interesting build, as this thing is only made of a few parts. They are pretty "big", and are folded many times to achieve all this faceting. The advice here is to go slow and only glue a little bit at a time:
    [​IMG]
    Detail shot of the front "face" section. This one is tough, again slow going is the watchword. I'm not totally happy with everything here, but I'm too lazy to redo such a large section. Again, few parts. In fact, all you see here is just 5 parts:
    [​IMG]
    And all the bits so far, sitting together. The clever idea the designer had here is that the 2 stages are never glued together. Rather, there are bits of metal glued inside the two parts of the ascent stage that sit on the deck of the descent stage, and 2 magnets glued to the underside of the upper deck of the descent stage. The result is that they stay together in the proper position, but can be separated! Neat!
    [​IMG]
    I'm frankly amazed that this was all done without software. The author states that this was done with pencil and paper. Amazing.
    Now things start to get really difficult, I think. All the leg structures and thrusters, and antennae are going to be a challenge!
    Rick
  2. rlwhitt
    Completed Ascent Module
    Finished the Ascent stage today. Man there are a lot of little bits to do on this!
    [​IMG]
    On to the Descent stage!
    Rick
  3. rlwhitt
    [​IMG]
    Rick
  4. Amazyah
    Amazyah Senior Member
    Your doing a great job Rick!
    It really looks good and a clean build too!
    Russell
  5. Amazyah
    Russell
  6. rlwhitt
    Thanks! I feel the hardests is yet to come getting those legs done correctly.
  7. rlwhitt
  8. cgutzmer
    cgutzmer Guest
    That is looking great! Thanks for the pics. I dont think I have seen a build thread for a similar type space vehicle before :)
    Chris
  9. cgutzmer
    cgutzmer Guest
    Chris
  10. Bengt F
    Bengt F Active Member
  11. Bengt F
  12. rlwhitt
    Thanks for the link, Bengt! Good stuff. I was interested to see that he rolled his nozzles the same way I did, with a toothpick. But then I guess some things only have so many ways to do it. :)
    Are you by chance familiar with the tool pictured in this photo?: http://www.kartonbau.de/wbb2/attachment.php?attachmentid=27970
    Boy, THAT would come in handy in about a thousand different ways!
    That CM and SM look really nice - do you know if he released files of the parts (or plans to, for sale or otherwise)? They look like the most detailed ones I've yet seen.
    Rick
  13. rlwhitt
    Rick
  14. Bengt F
    Leather Puncturing Tool
    Yes Rick,
    It´s a tool for making holes in leather belts and the like - I own a really old one, which works OK for thick leather or cloth. But it is a bit worn out and not sharp enough for thin paper or card.
    A new and sharp one would probably be very useful, though.
    The tool is very easy to center exactly where you want it and it rotates so you can pick the right diameter of the hole. Handy thing.
    Best,
    Bengt :grin:
  15. Bengt F
    Yes Rick,
    Best,
    Bengt :grin:
  16. rlwhitt
    It's Done! A challenging, yet fun build. Next time maybe I'll put on real foil. ;)
  17. rlwhitt
      File size:
      117.2 KB
      306
  18. barry
    barry Active Member
    Really good looking build
  19. barry
    barry Active Member
  20. Jim Krauzlis
    Jim Krauzlis Active Member
    EXTREMELY well done, Rick!
    That's a fantastic looking build. Although it's tough to imagine any improvements to the way it came out, perhaps real gold-colored foil would be the only thing that comes to mind...I'll help eat the Hersey almond kisses, if you need a volunteer! (Nah, gotta watch my sugar levels, now that I think of it :cry: ) That being said, it looks great the way it is, frankly.
    Thanks for sharing this impressive build with all of us!
    Cheers!
    Jim
