TSR 2 1/50th scale
Discussion in 'Aircraft & Aviation' started by barry, Sep 18, 2006.
  1. barry
    barry Active Member
    Hi All
    A change from soldering and writeups and having trouble with my servers FTP program so I decided to print this out it's lost the paintwork from the top of the fuselage. I should have (thought I had) made the nosecone in one piece so it looks a bit of a mess. The construction on this one is totally different 1 former in the nose 1 behind the cockpit and the rest is filled with tissue paper using the standardjoining ring. It looks like it will be about 12" long when finished. Thanks for the painting instructions Keith. All the lines will have to be traced eventually.
    [​IMG]
    [​IMG]
  2. Billy Leliveld
    Billy Leliveld Member
    Nice one Barry
    Where did it come from? ( Gotta get me one of those!)
    Cheers Billy!:rolleyes:
  3. Bowdenja
    Bowdenja Active Member
    I see a plane convert!
    Cool build barry!
  4. barry
    barry Active Member
    TSR 2 eflux end
    Hi All
    @Billy
    Sorry mate you will have to wait until it looks a lot better than this.
    @Bow
    This pure opertunism I got a professional mesh from Tim (Wunwinglow) which makes life extremely easy. There are a few aircraft I would like to design which have not been done before and much better than I produce. Like a Short Stirling, Sea Vixen and a Victor (even if it has been done).
    The after end has a former front and back and they are buggers to fit. Thanks to a comment from Bear I now use masking tape and glue to hold the darts together which has improved my ability to build planes by quite a bit.It ends up being built like an outside brick toilet (to be polite)
    Ships will always suit my abilities much better but this is a quick fun build amazingly the fuselage is straight.
    [​IMG]
    Tim's mesh
    [​IMG]
    underbelly
    [​IMG]
    [​IMG]
    [​IMG]
    One with a ruler
    regards
  5. Billy Leliveld
    He Barry,
    I had no idea that you where building your own design, way to go!
    I should have known, because I never found the TRS anywhere..I'll be pacient...
    I started to design the Ekronoplan, but I think it's to early to start a thread... ( don't tell everybody, but I build the plastic Revell kit as a reference)
    Cheers Billy
  6. barry
    barry Active Member
    TSR 2 wings
    Hi All
    More or less complete for a check build forgot to print out the flaps so it stopped here tonight. It looks like it has some promise needs a whole lot of redrawing the panel lines, undercarriage etc. Roundels look terrible.
    [​IMG]
    [​IMG]
    [​IMG]
  7. barry
    barry Active Member
    Flaps
    Hi All
    Last set on this one until it's reworked sometime
    [​IMG]
    [​IMG]
    [​IMG]
  8. sdk2knbk
    sdk2knbk Guest
    Looking really good so far, I look forward to the next one. One of my favorite "almost was" planes, along with the Avro Arrow.
    Scott K.
  9. t.l.williamsjr
    t.l.williamsjr Member
    TRSr-2
    Man, I hope you plan on releasing this to the community. This is one of the planes that I have fallen in love with, or at least its shape, along with the XF-103, Nobi's XP-56, and a few others.
    Thanks for the peak.
