Trucklover's Weathered Buildings
Discussion in 'Weathering Forum' started by TruckLover, Nov 15, 2006.
  1. Amrap1
    Amrap1 Member
    Do you thin down the india ink? Why ink and not paint?
    Ed
  2. TruckLover
    The rubbing alcohol is whats thins down the ink
    You can also use paint, if you want to do that, I would recomend Poly Scale Paints made by Testors and should be available at any hobby shop :thumb: :thumb:
  3. TruckLover
    :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
    Is that enough smilies? sign1
    Thanks again Steve
  4. Amrap1
    Amrap1 Member
    What's the ratio of alcohol to ink?
    Ed
  5. Amrap1
    Amrap1 Member
    Steve...
    Ed
  6. TruckLover
    Sorry Ed, been away from the computer for quite some time now :cry: :cry:
    It depends on how much you want to mix up, if you want a lifetime supply of the stuff, use the hole bottle of rubbing alcohol (70% isopropyl alcohol) and mix it with about 2 tablespoons of india ink to about a pint of alcohol. You can use more or less if you want to make bigger or smaller amounts. I usally do mixes in smaller craft paint bottles and I fill the bottle up to the bottom lip of the neck with alcohol and then add a couple squirts of the india ink in, I also made some brown wash and grey wash using the same method, using craft paints mixed with alcohol. You can also use Polly Scale paints too. Hope this helps and sorry for the late responce :oops:
  7. Amrap1
    Amrap1 Member
    Josh.....
    Thanks for the reply. I want to start practicing weathering on some building parts I bought at a show.
    Ed
  8. TruckLover
    Cool, start off small to build your confindence :thumb: :thumb: :thumb:
    Finally picked up some chalks at Micheals today so I can start chalk weathering and get this thread rolling again lol
