The O27 Design My Layout Challenge
Discussion in 'G / O / S Scale Model Trains' started by Cannonball, Dec 17, 2006.
  1. Cannonball
    Two 4x8 plywood boards for benchwork. Either L shape or 8x8 box
    4 remote control switches (2 RH and 2 LH)
    One 90 cross
    One 45 cross
    One bumper
    All the O27 track you need but no half curves or straights.
    Ready?
    GO!
    Yeah.... OK. this is just my cheesey way of asking for design ideas since I'm clueless.
    This is the best I came up with.
    (My figure 8 is off because I used straights and curves to make switches and the crosspiece.)
    Edit: Oops... One too many switches. None left for the side rail and bumper.
  2. Cannonball
    I like this better except I'm gonna run out of straight pieces before it's finished.
    (And I've used all 4 switches so there's nowhere to use my lighted bumper. :( )
  3. spankybird
    spankybird OTTS Founder
  4. Cannonball
    Whoah! :eek:
    Here's a few more I came up with.
    They all stem from the same basic idea but I keep adding to it.
  5. Cannonball
    One last one that didn't load.
  6. Dave Farquhar
    Dave Farquhar Member
    Cannonball, if you run out of O27 straights and need more, PM me.
  7. Cannonball
    I'm not sure I'm more worried about straights or remote switches. :D
    I need at least 3 more for that last layout. I came up with one layout that left me 5 short.
    Thank god for eBay when it comes to remote switches.
  8. Dave Farquhar
    Actually I've got some Lionel 1121 remote switches that I don't expect I'll ever use again. I know I have one pair that work well, plus at least one more. Not sure if its RH or LH. I have to use Marx switches on my layout because my Lionel locos like Marx switches better than my Marx locos like those 1121s.
  9. Cannonball
    You have a PM.
    You know.....
    I got to thinkin'.
    I should probably go measure my basement before I decide to put to 8x4 sheets of plywood down there for a layout. Might be a good chance there's nowhere to go with 12ft on one side.
  10. raybanduchi
    raybanduchi New Member
    Can I axe what software you guys were using?
  11. Cannonball
    RTS 7.0 Freeware
    Unfortunately, it doesn't give me all the options I need with the size of track I'm using so I have to fudge a bit and create my own by overlaping pieces. (The Altas O 21st Century library has no 90 crossovers or 27" switches.)
  12. raybanduchi
    Thanx
    I've tried to download Atlas Os freeware no less than 10 times, it keeps telling me it will send directions to my email, ... but I finally figured out they won't call, the check ain't in the mail and respect me in the morning---Huh!!!!
